Lead screw bearing stack on mini lathe
kjkrum
Re: Lead screw bearing stack on mini lathe
Post by kjkrum »
Bill Shields wrote: Thu Apr 08, 2021 3:48 pm is there a thrust bearing at the OTHER END of the lead screw? => gear end?
No, the headstock end of the lead screw just passes through a bushing. Its position seems to be entirely determined by the two thrust bearings on opposite sides of the block on the tailstock end.
