MSC 1336 taper attachment info needed
Just acquired a 1989 MSC 1336 lathe. It came with a taper attachment that was not installed on the lathe. The operators manual doesn't even show a taper attachment. It also has what I believe is the bed clamp for the taper attachment. My question is does anyone have a MSC 1336 with a taper attachment? If so, could you show a pic or two of the attachment installed on the lathe? I have had many taper attachments on lathes of different makes and models but this one is stumping me as to how it goes on the machine. Maybe I am missing a part for attachment? Some people have told me that MSC is an ENCO/Grizzly of the same vintage. Maybe some grizz or enco owners would know what I am talking about?????
Re: MSC 1336 taper attachment info needed
Pictures of the parts you do have would be of help. You might go to grizzly's web site and see if their parts breakdown for a similar lathe would give to some ideas. You mat be missing parts and you also may need to drill/tap some mounting holes. You basically have a generic Chinese lathe as also sold by Jet and others, and those outfits were never known for good manuals/parts lists etc.
www.chaski.com
I will post some pics as soon as I get the main body of it cleaned up as it was lying under the lathe unused. Bed clamp is like new. Still hoping someone has one like it.
