Forced Into the 21st Century
Re: Forced Into the 21st Century
I've been under the trailer, one side spring eyes are 3/4", the other side 7/8". I feel better.
A man of foolish pursuits, '91 BusyBee DF1224g lathe,'01 Advance RF-45 mill/drill,'68 Delta Toolmaker surface grinder,Miller250 mig,'83 8" Baldor grinder, plus sawdustmakers
- liveaboard
Ha!
That proves that you're not the first to go there.
I have a couple of the Hitachi VFDs. I am not an expert, but have successfully set up a few of them. Most VFD will run with either momentary of hold type switches. There is a FWD, REV and RUN commands. One can set it up as a run and stop on one switch and fwd and rev on another. Or fwd/run and rev/run. My lathe is setup the first way and the mill the second way.
In the USA, emergency stop is always set up as coast to stop. When using braking, there is a time constant setup with it, for which the braking cycle will use the entirety of while stopping. If something is trying to stop the machine at a faster rate than the time constant, the machine will add power to the the spindle, so it uses the entire time constant. If coasting to a stop the object can stop the machine at a shorter cycle than the time constant.
Downwindtracker2, send me a private message, if you would like, and I will see what I can do to help you get setup. I am in Washington state, just south of you, so we may be able to talk by phone.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
- neanderman
Sadly, that is part and parcel of living in a litigious society!BigDumbDinosaur wrote: ↑Thu Sep 16, 2021 9:26 amI just replaced our (gas) kitchen range and was a bit startled to see a 64 page owner's manual come with it. I was thinking "just how complicated can a stove be?" <snip> Are people really that stupid that they have to be warned that stoves get hot, boiling liquids can cause burns, and a gas flame can start a fire?
NO ONE wants to take responsibility for their own idiocy...err, ignorance..., err, actions!
So, it becomes the responsibility of the manufacturer to disclaim liability.
Granted, there are many cases where a manufacturer's design failure resulted in death -- but it has really gone beyond true, intentional liability.
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
