DC variable speed motors
Re: DC variable speed motors
Go to Automation Direct and buy a purpose-built 3-phase motor and inexpensive VFD. You'll save in the long run.
Conrad
The VFD is almost $200, so it's already more expensive than the sewing machine motor and you don't have the motor yet.Conrad_R_Hoffman wrote: ↑Fri Sep 03, 2021 9:48 pm Go to Automation Direct and buy a purpose-built 3-phase motor and inexpensive VFD. You'll save in the long run.
Advantage would be I can use one VFD to control two motors because I don't need to run the mill and the lathe at the same time (they will be on opposite ends of the same bench).
We have a surplus store locally that has 3-phase motors and occasionally VFD's, so I am going to check them out.
One vfd on two motors is ok as long as they can both run with similar vfd parameters.
You may well find that by the time you Invest in switches and boxes...you will have darn near the cost of a second vfd.
The reason for buying a purpose-built motor is they're designed to operate with a VFD over a wide speed range. A lot of the surplus/treadmill stuff won't be as satisfactory, but as a dumpster-diving cheapskate myself, it's worth a try and might get the job done.
Conrad
