Page 11 of 14
Re: Moriya Stirling Engine Build
Posted: Thu Apr 01, 2021 3:53 pm
by Harold_V
rmac wrote: ↑Thu Apr 01, 2021 3:46 pm
Harold_V wrote: ↑Thu Apr 01, 2021 3:37 pm
Generally the result of the tool making contact where it shouldn't.
That could well be what was happening. Working on miniature stuff with a pair of old eyes can be iffy sometimes.
-- Russell Mac
Yep! I'm no longer what I used to be, which I attribute, primarily, to my failing vision. I've noticed that when I don a second pair of glasses (reading glasses on top of my bifocals) I can see so much better.
I had a tendency to work with my nose close to the work when I was actively machining. I fully believe that my slight edge was due to the ability to see what was going on at the cut. It's ultra critical, and aided by an understanding of how a tool cuts, and how to make corrections when it doesn't cut as expected.
Posted: Thu Apr 01, 2021 5:46 pm
by Technical Ted
I have a pair of these as well as a pair of Optovisors. They both work great for small stuff like this. They fit over top of glasses just fine and I can wear them for extended periods of time with comfort. The Optovisor is a little better quality, but they are both fine.
https://www.amazon.com/gp/product/B0160 ... UTF8&psc=1
Ted
Posted: Sun Apr 04, 2021 5:54 pm
by rmac
Two new questions:
I have the parts for the crankshaft all made now, but haven't put them together yet. Any reason not to use Loctite for that instead of silver solder? It would save a lot of tedious cleanup work, for sure.
The next step then will be to make a couple of connecting rods. It seems odd that the plans call for aluminum for the parts that form bearings with the crankshaft (marked in red on the drawing). Wouldn't brass or bronze make a better bearing material?
-- Russell Mac
Posted: Sun Apr 04, 2021 6:29 pm
by NP317
My engine has both connecting rods made from 6061-T6 aluminum. The Power Conn Rod top is press fit (or glued) to a drill rod shaft.
They have shown no wear in the years of use I have subjected the engine to!
I did drill a tiny oil hole and cup on the top cap of the displacer conn rod, and oil it before every use.
The power conn rod top can easily be made from bronze, not being "captured" in the crankshaft assembly.
Their longevity has surprised me.
I imagine you could easily glue and pin the crankshaft. We silver-brazed them for my classes, as an instructional opportunity.
Yes, lots of cleanup to do after. Also part of the lessons.
Posted: Mon Apr 05, 2021 10:08 am
by rmac
Thanks, Russ.
Posted: Tue Apr 13, 2021 3:34 pm
by rmac
Progress Report #12:
Crankshafts, power cranks, and piston yokes all done.
NP317 wrote: ↑Sun Apr 04, 2021 6:29 pm
I went ahead and assembled the crankshafts with Loctite 609, then cross-drilled through the round parts for some little pins held in place by more Loctite. The pins don't show up very well in the picture, but they're there.
I didn't mean to, but somehow I managed to glue a pair of bearings onto one of the crankshafts. I put them on the shaft a day after assembling the crankshafts. All I can figure is that there must have still been some uncured Loctite on the shaft that I didn't notice. In any case, the bearings are NOT coming off now! Fortunately, they're in the correct position.
When cutting out the middle section of the main shaft, I found by experiment that it's easier to set up a slitting saw for an accurate cut than it is to file away the mess left when doing it by hand with a hacksaw.
-- Russell Mac
Posted: Tue Apr 13, 2021 4:16 pm
by NP317
Nice looking crankshafts + parts. You do quality work.
If I ever made another crankshaft for these engines, I would use your technique.
Funny that your bearings got glued in place too! No harm no foul.
None of us here have EVER done that. Right?
I just tore into my old Moriya engine today. The knocking sound was increasing and I figured it was time to evaluate it for worn parts and fix it.
Surprisingly it is back together and fixed now!
The work quality from my students (mechanical engineers) was not up to my standard. but they did punch mark the stacked parts so I could reassemble them.
The main stud holes were not precise in position...
The only part I replaced was the displacer piston rod. Its diameter was worn 0.001 - 0.002" in the brass seal/sleeve and had lateral movement in the hole! The brass sleeve was still true i.d. That surprised me.
Oh, I also replaced the wrist pin at the top of the displacer piston rod. The old one did not survive removal.
The split con-rod bearing at the crankshaft was a touch loose, so I sanded the top cap down a touch until it was close again.
When reassembled I attached an electric drill motor to the engine shaft and ran in the engine for several minutes until it was turning smoothly.
Moriya is now mounted back on my wood heater in the Shop, waiting for the next fire.
Check off another task.
Posted: Tue Apr 13, 2021 5:23 pm
by rmac
NP317 wrote: ↑Tue Apr 13, 2021 4:16 pm Nice looking crankshafts + parts. You do quality work.
Thanks. You can hide a multitude of sins with a little bit of emery paper and careful photography!
The work quality from my students (mechanical engineers) was not up to my standard. but they did punch mark the stacked parts so I could reassemble them. The main stud holes were not precise in position...
Darned engineers! I'm an EE by training but wound up doing mostly software for a living. All this metal work is just for fun.
I've been lucky on the stud holes. So far I've been able to assemble any combination of parts from both engines in any random orientation without any trouble. However I did match up the displacer piston rods with their respective glands after I got them all sliding nicely. Probably have to do that with the power pistons and cylinders, too.
Hmm. It does seem like the brass part would wear first.
I think I mentioned earlier that I plan to make those bearings out of brass instead of aluminum. Somehow aluminum just seems wrong.
-- Russell Mac
Posted: Tue Apr 13, 2021 8:42 pm
by NP317
"I think I mentioned earlier that I plan to make those bearings out of brass instead of aluminum. Somehow aluminum just seems wrong."
Wrong maybe, but 5 years of extensive use has proven the efficacy of the aluminum!
Posted: Wed Apr 14, 2021 8:08 am
by rmac
NP317 wrote: ↑Tue Apr 13, 2021 8:42 pm
Fair enough. In case it isn't obvious by now, I'm guessing at a lot of this. Aside from "aluminum works", is there any other reason
not to try the brass? Just for the bearing, that is--I want to make the rest of the displacer conn rod from aluminum to keep the weight down.
-- Russell Mac
Posted: Wed Apr 14, 2021 9:26 am
by NP317
I suspect weight was a deciding factor in choosing aluminum for the entire rod.
My engine is stock per design, except that the students used it ti research static balancing by adding machined weights to the ends the cranks.
Results are not highly evident, due to the small size of the engine and its lower operating rpm moving air.
But ti looks intriguing!
Posted: Sat Apr 17, 2021 9:40 pm
by rmac
Progress Report #13:
Displacer connecting rods done. I deviated from the plans a little bit on these:
1. Made the bearings out of brass instead of aluminum, as advertised earlier.
2. Put a little oil hole in the top of the bearings, per RussN's suggestion.
3. Made the fork and the rod as two separate pieces, just because it seemed easier.
These are stuck together with Loctite 609. I didn't bother with the cross pins this time.
Now I'm starting to wonder how to keep the little 1/16" OD wrist pins from working their way loose. Press fit them into one side of the forks? More Loctite (carefully applied!)? Blobs of epoxy on each end?
-- Russell Mac
