Trackulence
- Greg_Lewis
Trackulence
Re: Trackulence
Thumbs up!!
Re: Trackulence
Well Greg,
In actuality, there is a bit of truth to the cartoon. Trains rounding sharp curves or traveling downgrade are applying brakes. That force has a tendency to push the track in front of the train. Contrarily, trains accelerating or traveling upgrade have a tendency to push the track behind the train.
You might not see such track movement in the real railroad world. One of the reasons for "rail anchors" is to restrain such track movement...other than to minimize expansion/contraction of the track as a result of temperature changes.
In our scale railroad world, I've seen rail joint gaps disappear at the bottom of the hills most likely for the same reason. Luckily, we don't need to remove a rail section and move that back to the top of the hill! So while none of us will ever see a "washboard track"...the concept is still very real. Good cartoon...thanks for the chuckle! Carl B.
Re: Trackulence
Gary Larson. My all time favorite carton creator.
And now you know more about my sense of humor.
"Boneless chicken ranch"
- Greg_Lewis
Re: Trackulence
- Benjamin Maggi
Re: Trackulence
Well, if the track gets real bad just ask for more...
Re: Trackulence
If the bumps in the track were offset from each other, it would nicely portray the old bolted rail that got super lumpy.
I have childhood memories of my mother backing her car back up from a RR crossing, because the 40' gondola's of coal heading the power plant on the 40' jointed rails were bucking so badly she was afraid they were going to derail lol!
- Greg_Lewis
Re: Trackulence
rkcarguy wrote: ↑Tue Dec 15, 2020 4:52 pm If the bumps in the track were offset from each other, it would nicely portray the old bolted rail that got super lumpy.
Hey, you don't have to rely on childhood memories. There is some track out there that is still like that.
Re: Trackulence
Sadly this was a GN and then MILW line that was abandoned and finally torn up about 20 years ago, land auctioned off to the adjacent property owners. The remaining stuff is all fairly new BNSF trackage, so the only fix available is on YouTube, stuff like this:Greg_Lewis wrote: ↑Tue Dec 15, 2020 5:07 pmrkcarguy wrote: ↑Tue Dec 15, 2020 4:52 pm If the bumps in the track were offset from each other, it would nicely portray the old bolted rail that got super lumpy.
https://www.youtube.com/watch?v=tzNc57PYTeE
Re: Trackulence
There was an old joke about such track where the cars were rockin' and rollin' so much, that the rear end train crew could read the car names while seated up in the cupola (not really possible, but made for an interesting joke). Carl B.rkcarguy wrote: ↑Tue Dec 15, 2020 4:52 pm If the bumps in the track were offset from each other, it would nicely portray the old bolted rail that got super lumpy.
Re: Trackulence
There is an silent movie with Buster Keaton called Our Hospitality that had a train going over a track similar to that.
https://youtu.be/--cSbGU86Aw?t=1066
- Greg_Lewis
Re: Trackulence
Jtrain wrote: ↑Tue Dec 15, 2020 10:55 pm There is an silent movie with Buster Keaton called Our Hospitality that had a train going over a track similar to that.
Thanks! That's awesome! BTW, Keaton did all of his own stunts in that era, and in one of his other films he broke his neck during a railroad water tank scene in Sherlock Jr.
