I have 4 - Swageloc 1/2" S/S 316 ball valves with 1/2"OD S\S compression tube fittings .
These valves and fittings are brand new never used and are about the best quality valves you can buy .
The valves would be perfect for tenders , valves for water to injectors / pumps etc with a very smooth and easy 1/4 turn ON/OFF .
These valves can be panel / bracket mount or stand alone ,the fittings can be changed to suit application as they are standard NPT threads .
Existing handles can be removed and operated with a uni joint or remote shafting to required handle operating position to suit .
Replacement cost would be $300 plus to buy the valve and fittings new .
Asking - $125 US each - PayPal preferred
S/S Tender ball valves
- Chris Hollands
- Chris Hollands
Re: S/S Tender ball valves
New price - $105 each
The compression fittings are worth more than that.
Pity i already have a box full of these valves...
