Shop press
aametalmaster
Shop press
Post by aametalmaster »
My on going 17 year project. Started it 15 years ago and never welded it together. Then i finished it with a 6T jack which is what i had on hand when i really needed the press. Upgraded to a 12T for a little more push. I do driveshaft repair so i always have u joints to push out and in. I also do some keyway broaching in my custom pulleys i make. As well as repair anything my neighbors bring over to fix. Today i made a bearing splitter from 1" thick 4" sq plate to salvage some bearings the neighbor was going to scrap. he had a bucket full of them on electric motor shafts...Bob
Press start w 6T jack
Close up of jack mounting.
u joint tooling
u joint tooling
12T jack upgrade
12T jack upgrade
Some of my quick change tooling. All have 1 inch tops to fit inside the ring under the jack base. Just flip the handle and install.
Bob Wright Metal Master Fab
Salem, Ohio
http://www.chaski.com
aametalmaster
Re: Shop press
Some more pics...Bob
Split ring to hold the jack to the top of the press.
Turning the 1" flatbar for the bearing splitter.
Cutting the turned splitter in half with my 4x6 saw
bearing splitter split
pushing off the bearing
Salem, Ohio
aametalmaster
Re: Shop press
Pushing bearing and the bearing off...Bob
pushing bearing
pushing bearing
Salem, Ohio
pineyfolks
Re: Shop press
Post by pineyfolks »
Your split ring to hold the top of the jack is a good safety idea ,I may have to do that to mine. Thanks
rodw
Re: Shop press
Post by rodw »
Thanks for this. Your design got me thinking last night but I cheated and went out and bought a little press which will do what I need!
RodW
Brisbane, Australia
http://www.vehiclemods.net.au
aametalmaster
Re: Shop press
Made a rack to hold my pusher spuds. Some of them are 1" in dia and so are the holes and they fell thru. So i bored out some nuts and added a set screw to hold them to the shaft so now they won't fall thru...Bob
Salem, Ohio
aametalmaster
Re: Shop press
Picked up this press plate on ebay. Made from 410 SS with 15 holes. The largest is 2". Will work great with my little arbor press also...Bob
press plate
press plate
Salem, Ohio
ernest_t
Re: Shop press
Post by ernest_t »
You got shorted 2 holes.
