Amazing machine work
Re: Amazing machine work
RESPECT!
rmac
Post by rmac »
ENVY!
-- Russell Mac
Steggy
Post by Steggy »
GlennW wrote: Fri Apr 16, 2021 9:32 pm I took my latest restoration to an event this week and someone posted a video of me leaving on YouTube.
Next thing is to get those .50's working! :D I know a few places where they would be quite useful. :twisted:
shootnride
Post by shootnride »
What a thing of beauty ! Awesome accomplishment Glenn.
Ted
BadDog
Post by BadDog »
I believe I'm taking on a distinct shade of green.
pete
Post by pete »
A Merlin, P-51, and SHINY :-) Wot's there not to like. I'm very envious and more than impressed Glenn.
GlennW
Post by GlennW »
It will be heading in your direction to it's new home in a week or two, Pete.
Thanks!
pete
Post by pete »
Somewhere into B.C.? Or did you mean the Okanagan area Glenn?
GlennW
Post by GlennW »
Exhaust valve day.
The carbon was blasted off of the hot end and now the stems are being externally honed and polished until perfectly straight and round. It's a four step process. First a roughing stone to eliminate the wear, then a finishing stone to improve the finish and further straighten the stems. Then a polishing stone. Final step will be a Trizact polishing belt just prior to installation.
Next step will be the valve grinder for tip and face grinding.
Intake valves will be next.
RSG
Post by RSG »
Very cool Plane Glenn!
GlennW
Post by GlennW »
Connecting rod day.
Honing the small end of the rod round and straight for new bushings. Fixtured in the honing machine to keep the bore perpendicular to the beam.
Grinding the O.D of the connecting rod bearing block to eliminate wear marks and make it round and straight again. Fixtured in the Cylindrical Grinder.
RSG
Post by RSG »
Some fine precision work going on there! No doubt very important too for the safety factor alone! Given it's for an aircraft!
