Model........6K773AA
HP............2
Volts.........115/230
RPM.........3450
Phase.......1
Frame.......XJ56
Rotation....CW / CCW
Shaft........5/8” / Keyed
Currently wired for 115 volts. Runs fine!
Use the motor on your lathe, pump, drill press, band saw, table saw, planer, router or compressor!
Many other uses!
$245.00
Pick up ONLY!
Located near Detroit, MI.
