Switch to Full Style
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
tornitore45
Post by tornitore45 »
Every time I log in it comes up with a hideous format asking if I want to Switch to Full Stile
Sure I do, is there a way to set such choice permanently?
Mauro Gaetano
in Austin TX
J.Ramsey
Re: Switch to Full Style
Post by J.Ramsey »
tornitore45 wrote:Every time I log in it comes up with a hideous format asking if I want to Switch to Full Stile
Switch the page from mobile to full style, then delete your old bookmark then ad it back to your bookmarks.
I had the same problem after the last forum upgrade.
gwrdriver
Post by gwrdriver »
I'm having the same problem and that didn't work for me.
GWRdriver
Nashville TN
Bearing in mind I am not good with computers, I can't help but think that his is a cookie problem. You might try deleting your cookies, then entering the board once again, choosing the style you wish to use. Worth a try!
Marty_Escarcega
Site Admin
Post by Marty_Escarcega »
Harold_V wrote:Bearing in mind I am not good with computers, I can't help but think that his is a cookie problem. You might try deleting your cookies, then entering the board once again, choosing the style you wish to use. Worth a try!
It likely means that you are in the MOBILE STYLE which works best on tablets, smart phones etc.
Should be a link at the very bottom that lets you switch back.
Marty
