off topic
off topic
The discussion of the M D (Delta Milwaukee) in General Discussion reminds me of the MD-80 (McDonnel Douglas) aircraft which used a similar screw in the tail surface control surfaces. At least one nut failed the same way and planted a plane load of passengers off of the CA cost about 30 years ago. Interesting how such strange relationships come to mind. Much higher cost of failure in one case.
Re: off topic
Such failures in aircraft are exceedingly rare...fortunately. The jack-screw method of controlling flight surfaces is well-proved in large aircraft.Russ Hanscom wrote: ↑Sun Jul 25, 2021 6:18 pm The discussion of the M D (Delta Milwaukee) in General Discussion reminds me of the MD-80 (McDonnel Douglas) aircraft which used a similar screw in the tail surface control surfaces. At least one nut failed the same way and planted a plane load of passengers off of the CA cost about 30 years ago. Interesting how such strange relationships come to mind. Much higher cost of failure in one case.
That said, another McDonnell Douglas product, the DC-10, depended on hydrostatic lock to keep the leading-edge slats extended against the air stream. That design decision ultimately cost 273 people their lives at Chicago O'Hare airport in May 1979 when an engine tore loose and severed hydraulic lines in the left wing.
Re: off topic
My brother was First Officer of a DC-10 that had to abort takeoff from Dallas/Fort Worth, in 1988.BigDumbDinosaur wrote: ↑Sun Jul 25, 2021 9:46 pm [snip]
A warning light indicated the port leading edge slat retracted just as they rotated at V1. The brakes failed and they ran off the runway, cracking the plane through first class.
The only injuries were the three crew members in the cockpit, and 5 minor passenger injuries It was a fully loaded and fueled aircraft.
That was the last crash of a passenger carrying DC-10.
The FAA procedures were found at fault by the NTSB. Remarkable! The brake system was redesigned and all flying DC-10s were upgraded.
https://www.washingtonpost.com/archive/ ... f3a8d55a4/
Not steam, but personally interesting, and about failure modes and safety margins.
- neanderman
Re: off topic
After the O'Hare crash, I avoided DC-10's as much as possible. I much preferred the Lockheed L-1011.
Never flew on a 747.
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Re: off topic
I avoided them before that and in fact, only rode once on a DC-10 when it was unavoidable. Given a choice, I would take a narrow-body aircraft before a wide-body, as all of the models that were in widespread use were dependable and well-understood by flight crews. The L-1011 was a technically excellent aircraft, but Lockheed was still being shunned due to the L-188 Electra turboprop crashes. Also, some US airlines at the time didn't like Lockheed's choice of the Rolls-Royce RB211 engine to power the L-1011.neanderman wrote: ↑Mon Jul 26, 2021 3:00 am After the O'Hare crash, I avoided DC-10's as much as possible. I much preferred the Lockheed L-1011.
There were several mishaps involving the DC-10 in the early 1970s, the most serious being the crash of a Turkish Airlines plane in the Ermenonville forest in France in 1974. The aft cargo door blew off, causing the cabin floor to collapse due to the pressure differential when the cargo hold explosively decompressed. All control connections to the empennage were severed, causing the plane to enter a rapid descent from which no recovery was possible.
In 1972, an American Airlines DC-10 had a similar aft cargo door failure with subsequent floor collapse, but not all empennage control connections were severed. The pilots were able to maintain some control and make an emergency landing. The kicker was the possibility of such a failure was known to McDonnell Douglas, as Convair, who was subcontracted to build the plane's fuselage, had discovered it during testing before the plane went into full production and had made MD aware of it in a written memo. The FAA at the time was headed by a sleazeball director (John Shaffer) who instead of having the FAA issue an airworthiness directive to legally compel MD to redesign the door locking mechanism, merely "had lunch" with MD bigwigs and told them to come up with a fix. Lacking the AW directive, MD was under no obligation to do anything about the door.
The American Airlines incident convinced me to stay away from the DC-10. I knew enough about aircraft at the time to recognize a plane that had been designed by the accounting department.
I spent far too many hours in those things. That said, it is a remarkably safe plane. Although the 747 has been involved in two of the deadliest mishaps in aviation history, neither was the result of bad design. The majority of 747 crashes were due to piloting mistakes or improper repair procedures.Never flew on a 747.
Re: off topic
I recall that one. The slat warning was a false alarm—slats on both wings were found to be symmetrically extended. Had they not rejected the takeoff and overshot the runway everything would have been fine and the brake issue might not have been discovered...until the next time. I will say the cockpit crew was really on the ball—they wasted no time in making the decision to reject when the alarm went off.
- neanderman
Re: off topic
Excellent info.
Ed
Atlas 618
Atlas 618
