I posted a question about fixing the wear on the vise I am restoring.
The original post is here:
https://www.chaski.org/homemachinist/vi ... art=24#top
but there have been no responses because a lot of people that could answer that probably have not seen it.
Possible solutions could include welding or silver soldering a piece in, so it's more a question about that.
If you have a suggestion, please go over to that thread and post responses there, so that everything is in one place and not scattered across multiple threads .
Again, please post at:
Fixing vise wear - possible welding fix
Re: Fixing vise wear - possible welding fix
There goes the paint job.
I have successfully repaired vises by brazing, including repairing a cracked housing. You are going to need to heat the whole part to minimize distortion.
The opposite approach would be to use a nickle rod and arc or tig and build up the lacking area. The nickle should stay soft enough to allow machining. This method probably would be my first attempt.
