Primers
Re: Primers
Pete,
You might want to call or write to the company that made
your hand gun and ask them if it is built well enough for
your new home load. I know back in the 1970's I would only
shoot Super-Vel ammo. In the State of Wisconsin, the gun
stores would not sell them to you without having you bring
your gun into there gunsmith to examine the gun, and check
the manufacture’s ammo to gun safety sheets they had. The
liability was to great not to. You don't want to be shooting
your own hand held grenade..
Ken.
Ken.
One must remember.
Ken.
Ken.
Re: Primers
I was always told that rifle primers were made from slightly thicker metal and some pistols would have trouble hitting hard enough. For my 45-70 pistol I always used large pistol magnum primers and never had a problem even with very heavy loads.
Re: Primers
I rooted around a bit, and on several other forums (fora?), people said that in addition to being made of somewhat thicker metal, LR primers are about 0.010" deeper (or higher) than LP primers, so they may stand proud of the brass; which would make them prone to "slam-fire" in an autoloader, or maybe do a "roman-candle" in a tubular magazine. Conversely. LP primers being shallower, they'll just seat a bit deeper, but being thinner metal, they might perforate if used with hot loads in a rifle.
I don't know if any of this is really true; it's just other people's ramblings and ravings on the Internet. There IS, however, a certain consistency w.r.t. the height/depth/whatever.
Pete in NJ
Re: Primers
I have to backtrack a little bit, I also used LR primers in that same pistol (Ruger Blackhawk action)with no misfires.
A picture of it when it was still in white metal (can't pass up an opportunity to post a pic of it):
- warmstrong1955
Re: Primers
If you are shooting a stock handgun, I doubt there would be any problems with misfires.
I do know, that in something with some trick action work, like my PPC gun, misfires are the norm. Found out the hard way years ago.
Friend & myself were reloading, and I asked him to grab another box of primers. I should have looked before I slipped 'em in the tube.
We figured it out after we got back from the range from a little practice, which turned out to be more dry-fire practice.
They are thicker. At least we didn't reload a thousand.......
Super-Vel.....there's a name I haven't heard in a while.
Re: Primers
Yupwarmstrong1955 wrote: Super-Vel.....there's a name I haven't heard in a while.
Those were like Cor-Bon's and/or Buffalo-Bore's on Steroids
I saw quite a few examples of hand gun's with split barrels,
split cylinders and/or cases, that had to be pressed out of
cylinders, just because their handgun's were not tough enough.
They were not designed for the pressures that Super-Vel's
would produce.
Ken.
One must remember.
Ken.
Ken.
- warmstrong1955
Re: Primers
I saw a K-frame 19, that split the forcing cone. Only one I ever saw. Story was, sustained use of Super-Vels, and other hi-power reloads, was more than a K-frame Smith could stand.
I know that they were spectacular in my 2-1/2" Model 19 round-butt at night.
Re: Primers
I believe this is correct. I have a 454 Casull takes small rifle primers because of the pressures generated.DeMaxx wrote:I was always told that rifle primers were made from slightly thicker metal and some pistols would have trouble hitting hard enough. For my 45-70 pistol I always used large pistol magnum primers and never had a problem even with very heavy loads.
bedwards
Re: Primers
I was told the same, but I was also told that the primer chargebedwards wrote:I believe this is correct. I have a 454 Casull takes small rifle primers because of the pressures generated.DeMaxx wrote:I was always told that rifle primers were made from slightly thicker metal and some pistols would have trouble hitting hard enough. For my 45-70 pistol I always used large pistol magnum primers and never had a problem even with very heavy loads.
bedwards
is also Hotter which changes the recipe of the cartridge
over all and could pose a pressure problem. To High
Ken.
One must remember.
Ken.
Ken.
Re: Primers
Found this chart comparing the size of primers via a search engine. I thought it may be helpful.
http://i1248.photobucket.com/albums/hh4 ... nsions.png
- warmstrong1955
Re: Primers
