These are also great primer reads..
Mysteries And Misconceptions Of The All-Important Primer
http://www.shootingtimes.com/2011/01/04 ... ip_200909/
http://www.chuckhawks.com/primers.htm
http://www.handloads.com/misc/primers.asp
http://voices.yahoo.com/choosing-right- ... 77528.html
http://www.stevespages.com/primers.html
http://www.cci-ammunition.com/products/ ... _chart.htm
Ken.
Primers
Re: Primers
One must remember.
Ken.
Ken.
Re: Primers
warmstrong1955 wrote:I saw a K-frame 19, that split the forcing cone. Only one I ever saw. Story was, sustained use of Super-Vels, and other hi-power reloads, was more than a K-frame Smith could stand.
I know that they were spectacular in my 2-1/2" Model 19 round-butt at night.
Bill
Highly unlikely occurance attributed to repeated pressure causing fatigue because of location of failure. Pressure in a firearm like electricity, water, and all other things having to do with a driving force of any kind. Always seeks path of least resistance. Which would be the side wall of the cylinder. I've seen numerous revolvers "blown" from over pressure loads. And that is where they blow.
Much more likely that the revolver in question was incorrectly timed and the slugs were pounding the forcing cone rather than entering it in proper alignment and making a smooth transition from cylinder to barrel
JM2c.
