Hello,
I have a Remington model 7400 30-06 rifle that I'm having trouble taking apart. I can't seem to remove the pin that secures the bolt handle to the bolt. I've read that the pin is drifted out towards the bottom, but I can't get it to budge. Does anyone have experience removing this pin?
Thanks!
Remington 7400 disassembly problem
Re: Remington 7400 disassembly problem
Yes the retaining pin is driven downward into the receiver. The plastic cover (the half circle) is positioned so you can drive the pin . I recommend using a starter punch or 1/16 nail set (they don't break as easy) to get the pin moving. Then finish up with a longer punch. When you put the pin back in, the end that has a few raise marks on it goes in last. The purpose of the swagged lines is to make the pin bigger on that end to hold it in. To remove the barrel nut, you can make a wrench from a thick open end wrench. Just grind it back so it just clears the barrel ( a good sharp wrap with hefty brass hammer usually does the job to loosen the nut.
Super! Thank you for taking the time to help.
