Finishing AR 80% Lowers with small Mill ? ?
Moderators: JackF, Harold_V
Hylander
Post by Hylander »
Will this Little Mill Finish 80% AR Lowers.
I just found this local, new for $350 with some Collets a Vise and an air upgrade "What ever that is" ?
Milling out the FCG is the main part of the work.
http://www.harborfreight.com/two-speed- ... 44991.html
I did this one on a freinds big Bridge Port, but I would like to have a small unit at home for little projects like this. Will the HF unit get the job done ?
hammermill
Re: Finishing AR 80% Lowers with small Mill ? ?
Post by hammermill »
yes it will with some inventiveness the real challenge would be the magwell
Hylander
Post by Hylander »
hammermill wrote:yes it will with some inventiveness the real challenge would be the magwell
Magwells are already finished :)
So my main work would be the FCG
Would a used RF-31 be a better choice ?
ctrmass
Post by ctrmass »
I'm new at this, but I'm learning a lot.
IMO The rong fu 31 is considered inferior due to it's a round column. Not a big deal if you think you wont be moving the head up & down too much. Also, belts are a PITA to change speeds.
IMO You'd be better off with one of the square column models in the 1 HP range.
I may be getting one of these:
http://www.penntoolco.com/catalog/produ ... oryID=4493
I'm told that this is capable of about 75% of what a full size B'port can do.
Edit: For $350 I think I'd pick that up. It's about the minimum you'd need to do lowers.
I've done lowers on a $59 harbor freight drill press, but it shows. Yea, it'll function but looks like Fred Flintstone did it. :lol:
ctrmass
Post by ctrmass »
I just ran across this. It might be of help:
Rong-Fu's nomenclature for these benchtop mills is as follows:
* RF-20 - Round column mill/drill w/step pulley drivetrain
* RF-25 - Round column mill/drill w/step pulley drivetrain
* RF-30 - Round column mill/drill w/step pulley drivetrain
* RF-31 - Round column mill/drill w/step pulley drivetrain
* RF-35 - Round column mill/drill
* RF-40 - Round column mill/drill w/gearedhead
* RF-45 - Dovetail/square column mill/drill w/geared,rotating head
Rex
Post by Rex »
Hylander wrote:Will this Little Mill Finish 80% AR Lowers.
That will work just fine. With vise and collets that's a decent price. Keep it in good shape and you can get your money back, and maybe a profit years from now.
Nothing wrong with the round-column mill--drills. Lots of gunsmiths use them, but they are a bit crude.
I had one for a few years, but I rarely used it, preferring the minimill for most work. When I bought a Millrite, the mill-drill was sold, but I kept the minimill
