Erskine Tramway
Erskine Tramway
Re: Erskine Tramway
Post by Erskine Tramway »
Hi Folks...
A couple years ago, I bought one of those plastic wedge sidewalk snowplows from Amazon. I've been using it to help clear the track whenever the snow depth and consistency will allow. Running it with the 'road' wheels outside the rails works OK, but it has a tendency to hop over the ties and get out of line. So, this winter, I built a 4-wheeled truck to replace the wheels. Here's a little video I made a couple days ago of the trials. It stays on the track pretty well, the derailment in the video came from the end of the blade catching a frozen chunk of snow left over from the last time I shoveled it. The snow was shoveled wide enough to clear the train, but not the plow.
https://youtu.be/Sq3u8gEM7GU
Enjoy,
Mike
Re: Erskine Tramway
Post by NP317 »
Very Cool. Literally!
Looks like that plow might be happy on the front end of your electric power unit!
tomc
Re: Erskine Tramway
Post by tomc »
I need one but the asking price is to steep for me!
Tom C.
tom_at_srclry_com
A student of the Southend RGS!
Erskine Tramway
Re: Erskine Tramway
NP317 wrote: Tue Jan 31, 2023 11:59 am Very Cool. Literally!
Thanks, Russ...
I only plow 75-100 feet to haul the wood, so it's easier to just push it. In general, I try and avoid having to run trains in the snow by stacking a couple weeks' worth of wood in the Loco Shed alongside the garage. The only downside with the plow is that the end of the blade sometimes catches on ice or weeds (that I'll need to remove before next winter) or guardrails and twists the truck off the track. It's easier on the plow if I just push it :D If the snow's too deep or hard for the plow, I'm probably not going out there anyway.
Mike
Re: Erskine Tramway
Post by NP317 »
"If the snow's too deep or hard for the plow, I'm probably not going out there anyway."
I totally understand that!
Erskine Tramway
Re: Erskine Tramway
Hi Folks...
In case you ever wondered how Heywood couplers work, here's a little video I put together this week.
https://www.youtube.com/watch?v=STDMyTAb1F0
Enjoy, Mike
Chris B44
Re: Erskine Tramway
Post by Chris B44 »
Hi Mike,
I was looking at the flat waggons with the bulkhead ends you have made. I would like to make something similar for maintenance work at our club rather that piling stuff on a passenger car.
Can you let me know the general size of them, I gather they are 20” wide and guessing at about 40” long. Is there any form of suspension with the plummer block bearings and what wheelbase and wheel diameter are you using?
Whangarei Model Engineering Club
Former member Lincoln and District MES
Erskine Tramway
Re: Erskine Tramway
Chris B44 wrote: Mon Mar 27, 2023 2:38 pm Hi Mike,
Hi Chris...
Here's the original design. I changed some of it to make them quicker to build with what I had on hand, and I made them 20" wide instead of my Heywood's 18" wide. There will be an upcoming build article in 'Live Steam and Outdoor Railroading' magazine.
Bulkhead wagon.jpg (151.12 KiB) Viewed 3377 times
The suspension is by 'rubber' springs in holes in the bearing mounting blocks.
6-4-17 bulkhead wagon bearing spacer.jpg (107.23 KiB) Viewed 3377 times
The wheelbase is 18" and the wheels are 7" diameter RMI '2-1/2" scale' steel wheels. The wheelbase and overall length could be longer, I just wanted to make sure they would go around my curves without problems.
Mike
Chris B44
Re: Erskine Tramway
Post by Chris B44 »
Thanks for the reply Mike. I can start on the woodwork whilst my new workshop is being built.
Erskine Tramway
Re: Erskine Tramway
Hi folks...
A couple weeks ago, I had a derailment while I was shoving some loads of wood up to the Car Shed. It turned out that some of the ties on the top curve had weather checked badly enough that they weren't holding the track screws anymore, and the rail had spread on the curve.
So, I made a couple of videos of the replacement and surfacing. Here's the tie replacing: https://www.youtube.com/watch?v=p-a53vdb3xo&t=40s
Here's the surfacing. I didn't set enough handbrake on Sparky, and he wanted to run away a little while I was shoveling the ballast off. https://www.youtube.com/watch?v=CSvLC1i1UmI
Enjoy...Mike
