When you get it running come to Northern Ohio.
EMLS. We have 2 Sweet Williams running there. Currenltly
working on a third and fourth.
"Catherine", a USA "Sweet Pea" engine build
- Benjamin Maggi
Re: "Catherine", a USA "Sweet Pea" engine build
It was during the timing of the chassis that a terrible truth hit me: we had not yet installed the cast iron piston rings (previously purchased from Allen Models). Honestly, I didn't know they were needed at this time and I naively assumed they were to be put on right before actually running it on steam. I thought that running the engine on air didn't require the rings. And while technically I think that is true, we decided it was better to put them in now (and sufficiently lube the cylinders to prevent their binding and/or rusting) rather than wait for the future. So, part of the valve gear on each side was removed, the piston assembly was extracted, and the rings were carefully slipped on.
Putting the piston back into the cylinder without the rings binding was another matter. After trying random prodding/squeezing/poking methods my shop mentor hit upon the great idea of using a hose clamp. We slipped it over both rings, tightened it up, and gently slid the cylinder into the piston. The clamp was adjusted to only cover part of the ring, and we slid the exposed ring portion into the cylinder. The clamp was slid down further to only cover the other ring and the process was done again. In a couple of minutes it was done. I would LOVE to know how others do it though without a hose clamp!
I had heard horror stories of how easy they were to break but I didn't have that problem. But, one of my piston slots was cut slightly narrow on part of the piston and I had to gently open it up with a file until the ring slid into the groove.Putting the piston back into the cylinder without the rings binding was another matter. After trying random prodding/squeezing/poking methods my shop mentor hit upon the great idea of using a hose clamp. We slipped it over both rings, tightened it up, and gently slid the cylinder into the piston. The clamp was adjusted to only cover part of the ring, and we slid the exposed ring portion into the cylinder. The clamp was slid down further to only cover the other ring and the process was done again. In a couple of minutes it was done. I would LOVE to know how others do it though without a hose clamp!
Last edited by Benjamin Maggi on Sat Jun 03, 2023 4:56 am, edited 1 time in total.
At the WF&P our cylinder pistons are ~3" diameter. AS such we use a standard piston ring compressor as you'd see in automotive shops.
I don't think I've come across one small enough for our valves, which are about the same size as 1.5" scale main piston rings...
I've had some ideas for something, but no time. I was thinking a simple tapered bore to compress it enough to press in. But that'd take some effort.
Mike
Mike
My Logger loco project came with a ring compressor for the main pistons, and they are 2 1/4"
- Attachments
- PistonRingCompressor.jpg (116.94 KiB) Viewed 2749 times
I have used the hose clamp trick for 40+ years
Did not ever think to look for another way.
Think Charlie Purinton described it to me way back when when I was building my first engine and like a bright bulb asked how....
- Benjamin Maggi
Thanks all. I guess we were lucky and stumbled onto it (and I hate to think of how we would have done it otherwise!) If it was mentioned in a Live Steam magazine article I don't recall seeing it.
I also seem to remember doing it on a motorcycle 50 years ago when we were too poor to have a ring compressor of the correct size.
