How to drill flat bottom holes?
I want to drill a blind hole with a flat bottom and don't know how to do it.
My drills have 118 deg points and don't leave a flat hole.
Any suggestions?
Roger
Any suggestions?
Roger
drill blind hole
You could use a brad point drill bit. This will have a small point, but for most applications this works.
The only problem is that most brad point drills are made for wood. I still use one now and then.
Hope this helps.
Good luck.
Hope this helps.
Good luck.
Drilling flat bottom holes is no big deal, assuming you understand how a drill cuts, and you are able to hand sharpen. All the easier if you have a cutter grinder at your disposal, but certainly not necessary.
Sounds difficult, but it's dead easy.
Using a small square to insure that you get the drill flat, grind the end off the drill until you have a full diameter, then back off both sides so the drill has relief. You then grind a slight positive rake, enough to move the cutting edge to the center of the web, half from each flute. That operation is necessary if you expect the drill to be able to cut to center, and leave a flat bottom, not one that has a configuration of sorts, created by the flute. Be careful to not grind past the margin of the drill, otherwise it will cut tapered at the tip. It's OK to hit the margin, even to reduce it somewhat, but make sure you grind both sides equally, and that you have positive rake when you're finished grinding.
Drill your hole close to depth with a standard drill bit, then finish off with the flat bottom drill. Don't start holes with such a drill, they tend to cut well oversized until the margin pilots the drill well. That's why counterbores use pilots.
Store the flat bottom drill in an index for future use. You'll find they come in quite handy, particularly if you work with socket head cap screws.
I strongly suggest you avoid using an end mill for such an operation, especially if you have a light mill, or are using a drill press. End mills have the margin sharpened so they cut, unlike drills, which have the margin circular ground. The slightest irregularity in drilling and the end mill cuts the hole oversized. Use one only as a last resort.
you could also make a D bit if you just need to flatten the bottom of the hole. A piece of drill rod turned to size the ground so that half the end is gone (so the end view looks like a D) and a bit of relief on the back face. Harden and temper and tidy up with a stone or diamond lap. drill the hole with a normal bit then finish with the D bit. The D bit isnt good at clearing swarf so you cant take out a lot of material at once, but its good to get a flat bottom hole or an internal shoulder.
Theres no such thing as too many tools.
Thanks to everyone for their replies.
All were good suggestions but the last two by Harold_V and Big Pete seem to meet my needs the best.
Harold_V,
You lost me after the part about grinding the tip flat. I sort of understand about relief but it is hard to visualize what you are saying about positive rake.
So unless I have a vision I think Big Pet’s D-bit is most practical for me.
Thanks again.
Roger
Harold_V,
Thanks again.
Roger
rcr22b wrote:Thanks to everyone for their replies.
Harold_V,
D bits have their place, but this task isn't one of the better choices. They don't have a good ability to discharge chips--and take considerable time to create, very unlike altering a drill bit-----a drill bit that is created to cut and remove chips via helical flutes. In all truth, you could alter a twist drill and have your job completed before you could get a D bit roughed out-----let alone heat treat and grind it so it functions properly. It's simply too much work when there's a much easier and better alternative at your disposal.
I'm attaching three pics of what a flat bottom drill looks like in the hopes that they will help with the vision you need. The positive rake mentioned is nothing more than a minor alteration of the helix angle of the flute, whereby you grind the lip of the flute straight to the center of the web, so it becomes center cutting (although the one pictured isn't well executed----cutting to center was not a requirement). You have options of angle when you grind this alteration----so your choice should be to reduce ever so slightly the helix angle of the drill, not to grind it negative. Hope this helps.
- Attachments
- drill1-resized.jpg (19.66 KiB) Viewed 26624 times
- drill2-resized.jpg (20.49 KiB) Viewed 26624 times
- drill3-resized.jpg (22.74 KiB) Viewed 26624 times
