Does anyone have good detail pics of the stream heat roof vent detail on the rear roof section?
Very hard to find online.. most models don't have this detail
Any pics woud be helpful. The air intake vent will be my emergency motor cut out switch.
F UNIT STEAM BOILER HEAT VENT DETAIL
C&O EMD F7A 24vdc Locomotive(Museum Trains)
Chessie diesel switcher(5hp Free lance design) 0-4-0
Pine Grove Vineyards Davenport (Ride-Trains)Switcher 0-4-0
Wolf Run and Tambine Clishay 0-4-4-0(Bob Maynard design)
Mack Loco
http://www.neols.net (NorthEastern Ohio Live Steamers)
hondavt@windstream.net
Mack Loco
- makinsmoke
Re: F UNIT STEAM BOILER HEAT VENT DETAIL
Model Railroader Cyclopedia Vol. 2
- Attachments
- 5696B2E7-B23D-4A79-9E38-07856DFCF8F8.jpeg (687.11 KiB) Viewed 2435 times
- 4E94924B-A275-4FEF-9AF7-EBF097B8C148.jpeg (773.51 KiB) Viewed 2435 times
- makinsmoke
Guess they got what they needed….
Thank you for the information!
I appreciate the research for me., I would of thought it would take more time to find!
Mack Loco
Mack Loco
BTW, some installations had the steam generator (not boiler—two different animals) drawing combustion air from inside the engine room, rather than through the hatch, as seen in the above illustrations. Such an arrangement was more often seen with units that had been retrofitted with a steam generator than in OEM installations.
Drawing air from the engine room was discouraged by Vapor (manufacturer of most of the steam generators installed in locomotives) due to the slight risk of a flash-back through the generator’s air intake due to improperly-adjusted ignition electrodes or poor-quality fuel oil. I have personal experience with the flash-back thing—ended up with a face full of soot and a very black shirt.
