Brown & sharpe machine
Hi everyone i m quite New on this forum. I m hère because i have the opportunity to have this b&s machine attached as picture. But i dont have any information about it even the model num or if it IS complète or not or what may miss. The seller will give me the motor with the machine. Does someone have information about this. It would help me a lot thanks
- Attachments
- milling_machine.png (1.34 MiB) Viewed 3422 times
Reason: Enhanced Photo
Re: Brown & sharpe machine
No body have an Idea of this machine référence Num?
Me thinks it will be more trouble than it is worth.
Hi Bill. Sorry not sure ton understand. I m french in fact
This is a machine to repaire but i need thé ref ton have an Idea of what IS missing and if it will bé doable
That machine will be more trouble than it is worth.
I have seen lotsa Brown & Sharpe, my #1-1/2 is 1908, or 115 years old.
It has the name and serial number located in place.
From your photo, yours has apparently nothing, may not be B&S!
The B&S Site, of which I'm a part owner, is:
https://groups.io/g/BrownandSharpe/topics
In the photo below, you can see the cast in place B&S info:
Why do you believe the pictured machine is a Brown & Sharp?
Also, what work do you hope to perform on this machine?
Knowing this might help us... help you.
Because on thé other side i have this. Servpicture
- Attachments
- Screenshot_2023-05-03-20-27-33-474_fr.leboncoin.jpg (131.94 KiB) Viewed 3357 times
Thanks for posting that pic.
Yep! That last photo tells a lot.
Now what you should do is post those two photos on other sites.
B&S made a lot of stuff before 1900, with that extremely small table that machine may be 1880's or older.
All B&S Mills were Line Shaft until the 1920's when they came with electric motors, your mill has long ago lost any such parts, maybe.
https://www.amazon.com/s?k=Brown+%26+Sh ... nb_sb_noss
That's what I got, lotsa choices by going to Amazon.
As I looked again at that Amazon compilation I decided I would buy that book on B&S, where the company building is shown, do not have it in my technical book collection.
Maybe, I find a reference to such a mill??
Thanks a lot Ronald. I would Never imagine that this machine was si old. Do you think that it IS a good Idea to but if i m starting with milling
