Tender backup lights
$195.00
We just finished a run of lost wax cast brass Pyle National tender backup lights. These are a true scale model and work just like the Prototype utilizing 000-120 and 00-90 Hardware.
Lights are equipped with an LED circuit board when wired per the instructions will color change using a double pole double throw Center off switch which is not supplied flip the switch one way the headlight glows white flip the switch the other way the light glows red.
Equipped with a true fresnel lens. Light comes fully assembled with the lens loose so you can glue it in after you paint your headlight. Also comes with a short piece of 1/8 spring conduit and a blanking Bolt you can install the conduit and either side of the box and the blanking bolt in the other.
These will make an incredible addition and be functional to your locomotive or current project to order send me an email to
highiron@aol.com
Be sure to include your complete name mailing address and phone number. Do not attempt to make any payments online or through any of the payment companies except that methods or cash check or credit card over the phone
lights are $195 each plus shipping I will ship these internationally
Please note the last picture is of the actual prototype that the light was modeled from
As always thank you for looking and be safe out there
1.5 scale Pyle National tender backup light
- Attachments
- 20230206_180037~3.jpg (188.79 KiB) Viewed 7672 times
- 20230206_180020~2.jpg (481.13 KiB) Viewed 7672 times
- 20230206_180159~2.jpg (165.56 KiB) Viewed 7672 times
- 20230206_180306_HDR~2.jpg (74.63 KiB) Viewed 7672 times
- 20230207_081905~2.jpg (828.86 KiB) Viewed 7672 times
