Looking for someone to build a scale water tank
- Trainman4602
Hi All
I'm in search of a company or someone to build two scale railroad water tanks
- Attachments
- Galloping+Goose+Los+Pinos+Tank.jpg (176.42 KiB) Viewed 2619 times
- Charles T. McCullough
- makinsmoke
Re: Looking for someone to build a scale water tank
Hi Dave,
There have been hundreds of those D&RG/RGS water tanks scratchbuilt in different gauges over the years.
The plans are available readily and with your skills it would be fairly simple to construct.
The question is if you want them to hold water. They can be built from wood to hold water, but just like a barrel the staves have to be tapered to the inside to help seal.
Not much metal. The spout, of course. The hoops can be rod or flat.
It will be fun!
It will be fun!
- Trainman4602
I want it to hold 50 gals of water
- Trainman4602
I want someone to build two tanks with no spout they will be gravity fed to standpipes. Tank should have a float device inside for refilling. I think somewhere around 3 inch scale would do.
Used to call them "55-Gallon oil drums"... were steel, now I see lots of blue plastic barrels that hold liquids or powders. Fit a toilet refill valve to limit the level in the barrel. If looks is/are important, wrap it in stained plaster lath, with cable or straps for looks.
- Trainman4602
Man You guys are think headed I WANT SOMEONE TO BUILD IT SCALE NOT SOME CHEAP 55 GALL DRUM . I KNOW HOW TO BUILD IT THIS IS NOT WNAT IM ASKING. I WANT SOMEONE WHO CAN BUILD IT FOR ME. CAPICHE!
Tell us how ya really feel lol
I have 25yrs in residential construction and wood work. I’m currently building in 3” scale. Do you have plans and what level of detail are you looking for?
The car in the picture below is one I’ve built in 3”.
- Attachments
- CA5B5B36-1673-498C-BC3C-506A863001E7.jpeg (52.46 KiB) Viewed 2445 times
- 7CEDC36C-23C7-4E20-B5C7-B7A2CF91A82F.jpeg (76.88 KiB) Viewed 2445 times
“Jesus saith unto him, I am the way, the truth, and the life: no man cometh unto the Father, but by me.”
John 14:6 (KJV)
John 14:6 (KJV)
We have a true wood water tank at Ridge Live Steamers. I will take some pictures today.
Tim
Tim
Dave:
Perhaps the question to be asked is:
Would you mind if the construction was a wood outer shell, with something plastic or metal tank underneath?
It is often best to determine parameters of a project up front.
Dave,
From the photograph:
Tank diameter = 280 pixels
Tank height = 160 pixels
Platform height = 170 pixels
Based on the size of the vehicle on the track in the photo, let's guess that the platform is ten feet high. The tank dimensions then scale to:
Tank diameter = 16.4'
Tank height = 9.4'
and the real tank volume is about 2000 cubic feet, or about 15,000 gallons.
For a 3" scale (1/4 size) model, we'd have:
Tank diameter = 4.1'
Tank height = 2.4'
and a volume of about 32 cubic feet, or about 240 gallons.
This is almost five times the 50 gallon capacity that you mentioned in an earlier post. So I'm wondering if you want a 3" scale tank that will hold at least 50 gallons (no problem!), or if you want a tank that looks like the one in the photo that holds about 50 gallons when full?
-- Russell Mac
Tank height = 9.4'
Tank height = 2.4'
-- Russell Mac
