Centering Disc on Vertical Rotary Table?
Re: Centering Disc on Vertical Rotary Table?
I would be surprised it it were not.
I was hoping I wouldn't have to lift the 12" rotary table from under the bench to up onto the Bridgeport... It used to weigh considerably less
Step 1 Step 2
Step 1 Step 2
That makes sense
Doing that makes absolutely no sense. (to me!)rmac wrote: ↑Sat Mar 04, 2023 2:09 amGood point!
From the original question, though, I got the impression that mcman56 was going to immediately remount the rotary table vertically after he had the disk centered on the rotary table. If that's true, then the relation between the rotary table and the spindle would be immediately lost, and there's no reason I can see to temporarily mount the rotary horizontally in the first place.
-- Russell Mac
Setting up the rotary table/part with it horizontal and then flip it to vertical to do the work...
- Charles T. McCullough
Centering a disk on a rotary table is one thing and could be done in many ways, in any orientation, on or off a mill table.
Centering a rotary table on a mill table is entirely different and can be accomplished in many ways, depending on the orientation of the rotary table on the mill table and the need for parallelism of the axis of rotation of the rotary table to the axis of movement of the mill table.
GlennW wrote: Doing that makes absolutely no sense. (to me!)
rmac wrote: Doing what? I'm getting confused!
I agree. That's why I tried to suggest a way to center the part on the rotary table with the rotary table oriented vertically. Anyway, hopefully something in all this has given Dan the answer he needs.GlennW wrote: Setting up the rotary table/part with it horizontal and then flip it to vertical to do the work...
-- Russell Mac
Glenn Has an excellent method and as said , there are lots of methods
You may wish to consider a few more. All my rotary tables (TR) have accurate center holes
The one that did not was machined and reamed to size and I have a variety of plugs to fit
Set the vertical table on the mill and use a precision square between the table keyway and the face of the RT to square it.
Now have a RT plug that sticks out, like a 3/4 " drill rod maybe 3 inches . Have another 3/4" rod in the spindle , but that rod
has 1/2 diameter ( 3?8") removed like a "D" bit ( we will call it a flat ) Move Y axis until the flat is perfectly aligned with the end
of the Plug - You can use a mike and check differences until you get a .750" reading and you are there.
OR
the quick way
Accurately measure the RT Table OD and write or stamp it down - for future use
Put a Rod in the spindle OR USE the QUILL itself and run it upto the outside OD of the RT table and clamp the RT to the Mill table /reset DRO.
Move away and then move across the face of the Table exactly half of the RT Diameter+ 1/2 Quill or tool diameter...DONE reset DRO
Rich
OR
the quick way
Rich
That's exactly what I do Rich, using an edge finder. Detect R & L OD edges on the X-axis, and R & L OD edges on the Y-axis, divide the spread, Zero the DRO each way, and I'm done.
Something you've said made me realize that after the OD indicating process I've never indicated the center hole to see if that and the center hole and OD are concentric. Next time. If they are I'll use the center pin for indication.
GWRdriver
Nashville TN
Nashville TN
and if it is not, then you can just use a boring bar to 'make it so' after you have centered the ODgwrdriver wrote: ↑Thu Mar 09, 2023 5:56 pm That's exactly what I do Rich, using an edge finder. Detect R & L OD edges on the X-axis, and R & L OD edges on the Y-axis, divide the spread, Zero the DRO each way, and I'm done.
Then you will need to figure out if the center hole or the periphery of the table, or both, are concentric with the rotating axis of the table.
