Broken Taps
Broken Taps
I just broke a tap in a brass casting and looking for recommendations to get it out. I thought I read on the forum here of an acid that would eat the tap away with out attacking the brass, but I can not find the thread. It is a through hole and the tap size is 8-32. Any help would be greatly appreciated !
Re: Broken Taps
I recently broke one in the last hole in a complicated hard aluminum part. Not a worry. There are some videos on YouTube too that’ll get you in the ballpark.
I think you’re all set being in brass, not steel out of steel though with this trick.
I took my firebricks and made a fireplace, clean of oil part with the broken tap in it in a Pyrex glass wherever fits. I set the glass vessel on a 1/4” steel plate with the fire beneath.
Water up over the offending area.
Get from the supermarket in the spice aisle a pickling spice called Alum. I dumped the little oz or two of it in the water with the part. You need to keep the water at just about a simmer. It took a few hours and a can or two of Sterno. It was a blind hole. Once the bubbles stopped streaming from the tap piece in the hole-it was gone…and I finished the tapping with a new tap. Get an idea on the plan of attack from the videos maybe- but, it’s that easy.
The Alum costs three bucks and there’s always plenty to work on in the meantime
All the Best,
Paul
All the Best,
Paul
Re: Broken Taps
Tap Extractor. They come in sets and are also sold separately by size. Go slow and easy. Work both out and in a little at a time. Use plenty of cutting oil. If you break the fingers, you can purchase new fingers. The extractors come in 3 and 4 flute types but you can not use them interchangeably. Faster than Alum. I have had pretty good luck with the extractors.
https://www.aircraftspruce.com/catalog/ ... ractor.php This is a 6 pc set and is the type I have and use.
https://www.amazon.com/Samfox-Extractor ... 7231&psc=1 This type is a newer design and I have not used any of these. This type will allow you to insert to a limited depth and appears to be stronger where it counts: The fingers. Whereas the other type will allow depth to equal the length of the fingers or to the bottom of the tap but the fingers are more delicate.
I recommend purchasing ONE extractor of the size you require.
Good Luck,
Good Luck,
Re: Broken Taps
Walton Tap Extractors have been around for 100+ years. That said my experience with them has been very hit or miss, some machinists think they are a bit of a gimmick.
https://www.waltontools.com/products/extractr.htm
I've purchased a couple individually from McMaster-Carr:
https://www.mcmaster.com/products/tap-extractors/
-Frank K.
Re: Broken Taps
or find someone with a tap eroding machine, they are basically an edm machine and many are now portable.
Look at youtube there are plenty of home made setups as well.
Re: Broken Taps
Get some clay and make a dam around it.
Dab in some sulfuric acid or vinegar with a dash of salt..use an eye dropper.
As soon as the liquid starts to run out the bottom ..
plug it. Plumber putty will work.
Wait
Pick at it periodically with a dental pick. Dab in fresh acid / vinegar periodically. Allow to drain to get fresh acid in.
It will eventually dissolve.
Wait
Re: Broken Taps
My experience in refining precious metals dictates that that that would be a disaster. Brass is composed of a high percentage of zinc, which will readily be dissolved from the alloy, leaving behind a honeycomb of copper with little to no strength. You can see that happen almost immediately as the yellow color of the brass quickly turns red.Bill Shields wrote: ↑Mon Feb 20, 2023 9:21 pm Get some clay and make a dam around it.
Nothing quite like an Elox (edm made for tap removal) but alum might just be the smartest approach for the average guy.
- Dick_Morris
Re: Broken Taps
I've been able to remove a tap with a carbide dental burr in the mill. At least 8-32 is a lot easier than #2 or #3.
Re: Broken Taps
I've been using these things for years. They work great. In fact I used one at work yesterday.
https://www.penntoolco.com/omega-drill- ... al-drills/
Re: Broken Taps
Solid carbide ball endmill, Bring table up on miller will machine it right out. # 8 -32 is huge. Have used this method on as small as 2-56.
steamer
Re: Broken Taps
Carbide ball endmill is the best solution I have found after years working in the machine shop...if you have a ball endmill that is just slightly larger in diameter, than the diameter of the bottom of the tap flutes......you'll end up with little pieces, that u just pick out of your threads, that look like little hair combs...but be sure your endmill is not larger that your tap drill size
Re: Broken Taps
Years back when I had no kids and a lot more free time I thought a flat rate tap removal business would be a cool model. Idea being that the customer ships you part and a return label you burn it out with an EDM tap burner and ship back for a fee. It seemed like quite the little niche side gig. Is there anyone doing this. There's a lot off parts I would happily pay $50 for a tap to be removed over the years.
