Long shot does anyone recognize this motor?
Moderators: cbrew, Harold_V
ChooChooChris
Re: Long shot does anyone recognize this motor?
Post by ChooChooChris »
Fender wrote: Mon Feb 20, 2023 2:18 pm I bought a similar motor from ebay a few years ago, ostensibly 24 volts. No plate identifying the wattage, rpm or anything else. The rpm turned to be extremely high, leading me to believe it was actually a 12 volt motor. I ran it a few years, but eventually replaced it with a new motor with known specs when “the smoke leaked out” of the original motor.
Never let the magic go smoke out!
Anyways. Happy to report it made it through another 8 hour day. Still want to look into opening them up and seeing what type of P.M. can be done and see if brushes can even be replaced and that state of the gearbox. Other then that looks like we will just run em till they die.
-Chris Srch---- Home track Tradewinds and Atlantic Railroad
Steggy
Post by Steggy »
ChooChooChris wrote: Mon Feb 20, 2023 2:42 pmStill want to look into opening them up and seeing what type of P.M. can be done and see if brushes can even be replaced and that state of the gearbox.
You might luck out and discover you have self-commutating motors, which means no brushes.
