Silver soldering torches
Looking for recommendations on silver soldering torches, for some 1.5 scale detail part work, plumbing, half round on tender etc.
I've seen recommendations on turbo torches, etc but didn't know if there was a specific model/size that's ideal. Also I've read some references to using propane which would be nice.
Re: Silver soldering torches
For half round on tender top edges I've used soft solder paste and a small propane torch. Has worked fine on two tenders. Controllable.
For pieces using silver solder (45% and 56%), a MAP torch works for "smaller" parts, and oxy-acet for larger items that need more concentrated heat quickly. Also controllable.
- Greg_Lewis
Russ mentions O/A but it's important to understand that you don't set the flame the same as for welding. Doing so can easily end up with things getting too hot. Set the flame for a long feather — I set mine for about 12 inches. Then I heat the opposite side of the piece slowly and let the heat soak through. Don't rush it. I frequently set small stuff on a short piece of angle iron sticking out the side of the bench vise and play the O/A flame on the underside of the angle, letting the heat spread up and into the parts. And I highly recommend the black flux as it has a wider heat range than the white stuff.
I agree with Greg's advice.
Bigger than a handheld hardware store type torch but smaller and cheaper to run than my rosebud. Shown running at a couple psi. It'll run up to 20+ psi. It was about $12.00 to build. Simply a smaller version of foundry burners shown online.
"Measure twice, curse once."
If you want to purchase something and you gotta silver solder, there is Sievert, Sievert and Sievert.
after that, there is Sievert
in the above, i am using 2 Sievert torches to raise the temp to the point where I can just 'touch' it with the O/A torch to cause the silver to melt.
I know it looks clunky, but the firebrick are sitting on a board that is sitting on a lazy susan bearing, so that I can 'roll things around' as needed.
for smaller, on the bench parts, Sievert makes turbo tips.
torches are held by old milling vises that are accurate enough to hold torches
for really big parts...O/A is great but you can (as mentioned), have puddles quickly, and it really takes 3-4 hands to use a rosebud for general heating and a small tip for local heating.
milwron: that is a neat torch.
looks like a variation on an Oxygen Lance used to punch holes in THICK steel plate
Yep! It's spot on and will keep you out of trouble. It's all too easy to overheat when silver soldering.
Fact is, if one is soldering small items, it's hard to beat a furnace solder job, which heats uniformly and prevents overheating. That, of course, would not be possible with many items.
Curious how you utilize this torch, in general I love the idea as the commercial torches can be quite expensive.
Do you set this up pointing at the work for general heat and then apply spot heat with another smaller torch?
-Frank K.
Doing some googling led me to these
https://www.amazon.com/STK-9-TurboTorch ... B0006519QI
https://www.amazon.com/Sievert-Industri ... B01G5EWUA2
https://www.amazon.com/Sievert-Industri ... B00OTJ1IAE - looks nice because you can use a 20lb propane tank.
All look similar in size, the "turbo torch" is actually a little more expensive than the sievert
Any one in particular you'd recommend?
Much of the time I use the ball valve as a handle and use the legs just to set it down. I made it for silver soldering but most of the use has been for case hardening small parts that smaller propane torches struggle with.
That turbo torch looks like it mounts on a small bottle, which can be annoying to work with.
The sieverts that I use are interchangeable tips that mount on handles on the end of hoses connected to Bbq bottles with a regulator attached.
So I have 2 handles, 2 hoses, 2 regulators and maybe 10 tips..which also include long reach pipes because you do not want to hold one of the big tips on a 6" pipe, as you can see from the photo. The longest pipes that I have are 24" long and well worth having when warming a boiler from 2 sides at once.
Sieverts turbo torch has an interesting trick in that it seems to wrap the flame around a piece of pipe to warm more than just the nearest point...up to maybe 1" pipe. After that the flame just splashes around
Just an FYI
The last time I used my o/a rosebud to silver solder a copper boiler for a 1" scale loco, I chewed through a full size bottle of acetylene before it was over and my arm was very tired from waving it.
Building a brick semi enclosure and hitting it with sieverts is a lot easier...kinda like what Harold recommended...a furnace is a nice way to go.
Wish I could figure out a way to do an entire boiler in an enclosed furnace...
Just an FYI
- Greg_Lewis
I did some relatively large assemblies, about the size of a lemon, using the brick enclosure that Bill mentions, and a weed burner from Horrible Fright. The only issue was the heat bouncing back at me, but I only did four of these, if there were more I'd have figured out a solution for that.
