X-axis feed for Select 6x26 mill.
Davisa
Post by Davisa »
Does anyone have any info on which axis feed will fit on a Select 6 x 26 Taiwan mill? I've had it for over a year and it's time to upgrade it.
Any info would be greatly appreciated.
Davisa
wally318
Re: X-axis feed for Select 6x26 mill.
Post by wally318 »
Take a look at my thread Rockwell milling machine rebuild @ top of page.
Look at page 3 & 4 . Should give you some ideas.
Every power feed will require a certain amount of adaptation.
Reason: Added link to the other thread
Post by Bill Shields »
As much as you may not to want to go this direction, but Servo feeds provide the most comprehensive data for installation dimensions.
They are also the most $, but have been around for decades and provide parts and service you may not get from others.
