Nicholson has a file listed in their catalog as a Plastics file mode# 06612.
Described as being designed for nylon/ UHMW etc(softer materials)
I can't find it listed for sale anywhere.
Do any other mfg's make anything similar?
Plastics File
Re: Plastics File
Try MicroMark as they specialize in model making tools and supplies. On a side note, I would think any standard file would work however It should be dedicated for plastic only.
Re: Plastics File
A Google search turned up this place . Looks like they might sell you one. The file you're looking for appears about 2/3 down the page in my browser.wally318 wrote: I can't find it listed for sale anywyere.
-- Russell Mac
Re: Plastics File
I use a vixen file in soft stuff
While not specifically designed for plastics...I have them and they seem to work ok for my needs.
Re: Plastics File
I checked out Roberts, but they're wholesale and not worth it for the hassle of setting up an account for a
1 time small purchase.
Bill, thanks for your suggestion. After a bit of searching/research I settled on
the idea of Japanese milled tooth files at Lee valley.
I went down with a few pcs of plastic to test. Although the teeth and very positve rake
and extremely sharp compared to the run of the mill files we usually deal with.
They proved a bit too agressive. The salesman also brought a Bahco Handy file.
It has a coarser cut on the 1 side and finer on the other. It seemed just right.
When I got home I chucked 1 of the pcs in the lathe. The file made a nice chamfer
and also quickly formed a large radius, with a nice smooth finish.
I will dedicate that file for plastics only. Thanks.
Re: Plastics File
Take a look at Crescent Nicholson #06992N 10" Double/Single cut Bastard file Safe Face back. It is a triangular knife edge file. They make a 4" #06711N, 6" #06804N, 8" #06898N, and 12" #07085N. I have seen these used on plastic laminate edges. A file card cleans the plastic bits out of the teeth, lickety split. See if this one will work for you.
Terry
Terry
