ID this rail?
Forum rules
ID this rail?
Hello all,
I recently acquired a quantity of rail from an estate. 3000’ of this unusual light rail was included in the purchase. Iam trying to identify origin and what it has been used for. We have some similar rail down in Phoenix, with MLS. It has been suggested this profile was originally used with MTC G-12
Train sets.
Dims are: 2” tall, 2 1/4” base, 3/4” head, 5/32” web thickness.
This rail is generally same dimensions as 12# rail, but about half the weight…
Anybody have any suggestions?
Train sets.
Re: ID this rail?
Use it for storage, sidings and passing tracks.
Re: ID this rail?
My guess it’s factory G16/G12 rail.
It had a slightly narrower railhead than 12lb.
Glenn, few months back you you had mentioned some 8lb rail that need pulled up, is this the rail what you were talking about ?
“Jesus saith unto him, I am the way, the truth, and the life: no man cometh unto the Father, but by me.”
John 14:6 (KJV)
John 14:6 (KJV)
- Erskine Tramway
Re: ID this rail?
It's called 'sub-purlin' rail. It's intended purpose was as part of roof framing in (usually) steel buildings. In the late '50s, early '60s there were a couple clubs in suburban Chicago using it for rail.
Mike
Mike
Re: ID this rail?
Yes, this was included in a purchase of 8# rail from an estate. They had used this rail with the 8# rail in trackage.
Mike, thanks for the info.
Re: ID this rail?
Glenn,
I have to agree with Mike as I have 8, 10, and 12 lb rail profiles and that one is thinner than the 10 lb I have. With that skinny web, I wonder how much weight it could safely handle?
Good Luck.
Good Luck.
- Trainman4602
Re: ID this rail?
This is not Railroad Rail at all. It is an industrial shape that is used on the underside of steel trusses to build a dropped ceiling. I had some of this stuff years ago. although it looks similar to rail it is not used for that purpose it can be but as you can see the rail head is sharp not radius like actual rail. At one time I had 15,000 feet of 8 pound sold it all.
- Greg_Lewis
Re: ID this rail?
Glenn, please check your private messages. Thanks.
Re: ID this rail?
Hi,Greg,
Thanks. Saw your pm. Sent you a quick update via PM.
