Bauxite is still mined in the U.S., but since 1981 the bauxite mined has not been used to produce aluminum, only other industrial purposes such as abrasives.
Nyle
The price of steel
Re: The price of steel
I'll bet those are pretty high-grade steel.JackF wrote: ↑Tue Dec 13, 2022 12:07 pm Just a thought; here in the Boise area there is a lot of irrigation for the farms. One of the machine shops I buy shorts from said another source for shafts is pump repair shops. They will sell the damaged motor shafts. I haven't tried that yet but will when needed.
- tornitore45
Maybe, but the 1, 2 HP pump motor shaft I cut from the rotor cut like 10L14I'll bet those are pretty high-grade steel.
