Ebay: Upgraded Emco compact 5 CNC PC-complete setup
Posted: Sat Dec 03, 2022 11:18 am
Selling my CNC lathe: https://www.ebay.com/itm/394361745389 Message me if you want to talk about a deal.
Emco Compact 5 CNC PC w/laptop+Mach3
Upgraded with a larger hardened/ground steel chuck from Little Machine Shop, which makes it a joy to use.
Included in the sale: Dell Latitude E6500 laptop running Mach3 under Windows 7.
A good selection of tooling, including a new set of Shars cutting tools, a quick change tool post (mounted), reversible jaws for the chuck, MT2 collets, individual reamers and bits, and a drill chuck w/key.
Also includes an automatic tool changer! It's not mounted, but the previous owner used it and included instructions on how to mount it and get Mach3 to talk to it. I never needed it for my simple setups.
See the photos for what you will receive. Lathe works perfectly. Only selling to upgrade to larger iron.
My company ships industrial equipment every day, so I will build a proper crate for the machine at cost. USA only!
