Did someone say hydraulic hedge trimmer?
Lathe chuck xmas tree stand
- liveaboard
Re: Lathe chuck xmas tree stand
can you put it above a christmas tree, pitched at an angle and 'circle your way around' ?
i strongly suspect that what my neighbors use is derived from what you have there...
- liveaboard
my turning circle is a bit large, but the height and angle are no problem.
Just have to reverse and come from another direction.
Nothing is derived from this thing, it's all home made. But there are lots of similar factory built ones, and ones with circular saw blades that will cut through larger branches.
- liveaboard
My hedge is 10' high, 10' wide, and 400 yards long...
https://www.youtube.com/watch?v=cAu8WVSGzw8&t=60s
cool...
what if your hedge is 10' high, 4' diameter and tapered like a Christmas Tree???
can the tractor sit stationary and spin the trimmer around the top of the hedge???
https://www.cgernon.com/sptf/trimming.htm
granted - it is a VERY SPECIALIZED business
it is very important that the taper be accurate to 0.1 degrees
- liveaboard
No; we don't do Christmas in our house, or bring a tree inside to die, so really I have no use for that function.
Or maybe I would have built it.
