All--
I'm building another small stationary steam engine. I need a reamed hole for a 0.125" piston wrist pin. It doesn't have to be reamed . . . but why not do it anyway?
So I mounted a #31 wire drill (0.120" dia.) and drilled the through-hole. Then I mounted a 0.125" reamer. All went well.
That is until I pulled out my plug gages and checked the diameter: 0.134". Huh. What had I done wrong. I looked at the reamer and it was indeed a 0.125" tool that came from McMaster-Carr. It must have been the drill bit. I must have stuck a larger one in the hole marked #31 at some time, since one box of bits got dumped and I had to reinsert a bunch of wire drill bits. I mic'd the bit. Right on the money.
I couldn't figure it out.
Then I could. When I said "mounted" what I actually did was put the bit and then the reamer in my 1/2" keyless chuck. No good!
As a test, I mounted the #31 drill bit in a collet and remade the hole a little farther down the line on the piece of 5/8" 1018 round stock I am using for the piston. Being somewhat anal (by now), I checked the hole size with a plug gage. 01.20"+ would just fit. Then I reamed it with the 0.125" reamer from McMaster-Carr. A 0.125"+ plug gage just fit but a 0.126"- wouldn't fit.
I've built several of these engines before and didn't experience the problem. Luck. I'll remember that collets are the key.
--Bill
ps I don't ream a lot of holes. But I think I will investigate floating reamers.
Basic reaming mistake
- seal killer
You are what you write.
Re: Basic reaming mistake
Welcome to the world of accurately reamed holes.
It's a bigger problem in a lathe tailstock
Just curious, is it a particular kind of collet that you were using to hold
the #31 drill or were you relying the grip range of the collet to hold the drill bit ?
- seal killer
Ah-Ha ! grip range, thanks.
I'm confused, not an unusual occurrence. I drill and ream using nothing but chucks all the time and never have a problem. Have you checked the runout of your chuck? Reamers are long for a reason. They can deflect a bit to follow the hold, rather than try to redefine the center. Don't chuck them up near the flutes.
Conrad
Yep!
I had started a post on this subject but didn't complete it. Maybe I should have.
Even with a lousy chuck, acceptable results can usually be achieved by gripping the reamer by only the last ¼" or so. That allows the reamer to seek center effortlessly. The long slender shank helps with alignment, so the reamer has less of a tendency to behave as a boring bar.
The same concept applies to the use of a center drill, especially when used in a lathe. By gripping the center drill by a short portion of the shank, assuming the operator allows a reasonable amount of time for the center drill to find center before applying enough pressure to start drilling, the tip of small center drills (#1 or smaller) won't be broken. I often just hand tighten the (keyed) chuck when using a small center drill so there's little resistance to the drill seeking center.
- seal killer
Conrad and Harold--
Mistake #2: I had a choke hold on that reamer. All of the shank was stuck up in the collet. Thank you for the guidance.
When I reamed holes for the earlier engines, I probably gripped the shank more like it should be held.
--Bill
--Bill
