Ok, so if it's not Mild steel then what could it be. I assumed it was 1018 as I read that it can have a Brinell between 120 - 180 that would put the test of 155 in that range. Unfortunately, I am no expert at Metallurgy and I am trying to get a better understanding. Based on the hardness chart 30 Rockwell is equivalent to a Brinell of 313 or so.
I addressed that in my comments in post #323. I suspect it's medium carbon steel (1045).
- Dick_Morris
Haven't I read that heating with a carbon rich flame will add carbon to the steel?
Maybe I should have asked, what number steel, sorry. So, it occurs to me that I have a coal burning stove to supplement heat in my house. Can this be used as a heat-treating oven for this steel? Also, would I still need the Heat treat compound and how long would I leave the links embedded in the red-hot coals?
Today we remade the Crossheads out of 954 Bronze. They were made on a CNC machine so I trust that they will be accurate and per the plans. Due to numerous setups, it was a full day to complete them however well worth the effort. I still need to tap all the holes however a small part of the project.
- Attachments
- CrossheadBlockSquaring.jpg (312.81 KiB) Viewed 551 times
- CrossheadRadiusCut.jpg (292.14 KiB) Viewed 551 times
- CrossheadPistonRodBoss.jpg (324.39 KiB) Viewed 551 times
- CfrossheadFitCheck.jpg (399.69 KiB) Viewed 551 times
- CrossheadFinalSlotCut.jpg (258.08 KiB) Viewed 551 times
- CrossheradsTopSide.jpg (228.35 KiB) Viewed 551 times
Ody...gotta luv it when the drawing looks like the part that falls out of the machine! Nice work. Carl B.Odyknuck wrote: ↑Sat Mar 11, 2023 10:04 pm Today we remade the Crossheads out of 954 Bronze. They were made on a CNC machine so I trust that they will be accurate and per the plans. Due to numerous setups, it was a full day to complete them however well worth the effort. I still need to tap all the holes however a small part of the project.
Awesome! I love CNC machine work. It produces functional art.
Those crossheads will meet your needs!
Yes, it will, but it's a slow process, much the same as pack hardening (ten thou per hour penetration). The heat treat company I used to use when I ran my shop did that and also controlled the atmosphere of their heat treat furnaces to limit oxidation, all by introducing extra fuel (natural gas in this case).Dick_Morris wrote: ↑Sat Mar 11, 2023 7:33 pm Haven't I read that heating with a carbon rich flame will add carbon to the steel?
Hmmm. Not sure about that. It's desirable to use the correct temperature, which you most likely could not do.Odyknuck wrote: ↑Sat Mar 11, 2023 9:04 pm So, it occurs to me that I have a coal burning stove to supplement heat in my house. Can this be used as a heat-treating oven for this steel? Also, would I still need the Heat treat compound and how long would I leave the links embedded in the red-hot coals?
The harsh reality is if you have red hot coals, they alone may provide the needed carbon. Think of a blacksmith's forge. As long as the piece is surrounded by carbon and is heated to the critical temperature, you're bound to achieve some degree of carbon absorption. What would be important, then, is that you don't expose the heated piece to free oxygen. When one pack hardens that doesn't happen, so the part isn't altered by oxidation (scaling).
You should also understand that heating a piece in the open (or in an oxygen rich atmosphere) can be the cause of carbon loss. That's why they talk about decarb when you purchase tool steels. The outer surface (which has had the needed carbon burned out) has been removed so the material will heat treat to specs.
Very nice work. They will be a pain to keep polished . LOL
No problems just solutions.
Thanks djjh87, I will probably just paint them black.
Yes, I do, as you know going in that both parts will be the same, even when it's a left/right design.ccvstmr wrote: ↑Sat Mar 11, 2023 10:28 pmOdy...gotta luv it when the drawing looks like the part that falls out of the machine! Nice work. Carl B.Odyknuck wrote: ↑Sat Mar 11, 2023 10:04 pm Today we remade the Crossheads out of 954 Bronze. They were made on a CNC machine so I trust that they will be accurate and per the plans. Due to numerous setups, it was a full day to complete them however well worth the effort. I still need to tap all the holes however a small part of the project.
