very nice indeed - fiddly bits to hold
it is amazing how we (most of us anyway) -> use a BEARING MATERIAL for a brake shoe.
is a bit of an oxymoron
think about it....
think about it....
Steve:
The two radius rods for the trialing truck on my Mikado are made from 1/8" thick hot rolled steel bar.
You might find greater success using the thinner bars. They are under very small stresses in use, acting primarily as guides.
I have bonded 1/8" thick brake pad material to the bronze shoes on my railroad equipment. JB Weld works well for this.Bill Shields wrote: ↑Wed Jan 11, 2023 11:53 am very nice indeed - fiddly bits to hold
think about it....
McMaster-Carr supplied the friction material.
This works especially well on the tender truck brakes, since they are hauling my body weight around...
I do similar.
Are you saying that weight of tender+butt > weight of loco?
That depends on lunch and dinner... and the locomotive.Bill Shields wrote: ↑Wed Jan 11, 2023 12:13 pm [snip]
Thanks guys for compliments, means a lot to an amateur at this.
I offset the Trailing Truck radius arms and now have 3/8" clearance. I also put the on a slight angle to help steer the truck thru curves.
I call that 'beat with a hammer until it cleared'.....you are doing a very nice job, looks very nice.
same result -> your description more elegant....
Have room in there for the ashpan / dump? or are you going to oil / gas fire?
I know this next section is going to sound pedantic -> but those of us who have been through it will understand.
Imagine your loco in the upright, wheels down position.
Imagine NEXT -> what happens if (when?) a bolt falls out of the brake rigging and a piece of linkage drops down.
worst case is it drops so that the leading end is jammed into an oncoming tie (or switch frog....) and the track / switch is ripped up and / or the loco lifted and derailed (or both)...There are few things in the world more unwieldy than a hot, heavy locomotive.
Many of us who have been through that -> put pins in from the top down, with a cotter to hold them in place - often in addition to threaded nut. On one of my locos, I have 'safety straps' to keep things that may come loose from falling down below track top level. (you may have seen them on passenger cars / freight cars under the brake rigging rods).
Whenever possible, I prefer soft, non fracturing pins in place of hardened bolts that can snap off under a load.
yes, the loads are small, but then *things* happens and murphy is resident at most LS tracks..
there is a lot of motion going on down there, and things work loose (and / or break)....and don't get inspected on a regular basis since it IS the underside of a largish loco.
The aircraft industry calls their solution 'safety wires'
Thanks much Bill. I don't find your words pedantic at all. I am always open to good dialog, good, bad or indifferent as I typically take something positive away from it. This is all great info as the last thing I want to do is have a link fall off. I planned on using Nylock nuts and Blue Locktite on all fasteners. As you say the bottom of the Loco's do not get inspected as much as one would like. I will say with my stand on the air lift I will have easy access from below to check things out. I am going with Propane for fuel
BTW, I did beat those links with a hammer lol. They were however done side by side to make them the same. As the old saying goes, everything bolts on if you have a Hammer, Welder and a Machine Shop!
Bill Shields stated:
"...put pins in from the top down, with a cotter to hold them in place - often in addition to threaded nut. On one of my locos, I have 'safety straps' to keep things that may come loose from falling down below track top level."
Wise words, and I follow the same methods.
I finished up the brake linkages and few other parts, prepped and painted.
Pretty much every fastener on the project was loose and/or did not meet the 1.5 Diameter engagement when I got it. So, I dissembled the frame to the point I could address the issues. A lot of the allen cap screws had to be replaced with longer ones. A lot of crud was left in blind holes so I chased the threads with a tap to clean them up and blew them out. Also discoverd another issue of holes drilled in the wrong location.
