Backyard Rails Info
ccvstmr
Backyard Rails Info
Post by ccvstmr »
Hello all...
Is there's anyone out there in Chaski-land with a Backyard Rails F-7 or GP-50 loco? Looking for info on the headlight Don Phillips used in his loco production. Know the lamp is a 2-pin, 12 volt bulb...but I can't read the info for the wattage rating.
If someone knows this tidbit of info, would appreciate a response. Thanking you in advance. Carl B.
ALCOSTEAM
Re: Backyard Rails Info
Post by ALCOSTEAM »
I used to run into Don Phillips on occasion and tried each time to get him to visit us out at the shop given he was only about 10 minutes away. Its been several years since the last time I run into Don at a restaurant and his wife seemed quite displeased of the mention of trains or shop visit.
Do you have any info off the bulb. Even a picture and dimensions might help. There is always the option of going LED as the power consumption is so low.
ccvstmr
Post by ccvstmr »
Hello Alcosteam....thanks for responding.
Yes, I am considering changing to LED at this point. A warm white option would be great! Otherwise, a cool white will have to do. Info on the bulb identifies: a 2-pin, GE, "BNB", 12 volt...but the watt rating is missing. The bulb is 2" diameter across the reflector. How's that? Carl B.
Bob D.
Post by Bob D. »
I think that is a M16 bulb. You can get them in various wattages but I would think a 20 watt warm white would be good. These are a halogen bulb. Amazon has them and I think Home Depot does too.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
ccvstmr
Post by ccvstmr »
Bob...thanks for that heads up.
Alcosteam...meant to write "BAB" not "BNB" for the bulb type.
Carl B.
Greg_Lewis
Post by Greg_Lewis »
The BAB is an MR16 bulb with a 20 watt rating and a 35 to 40 degree beam angle:
https://en.wikipedia.org/wiki/Multifaceted_reflector
https://www.lrc.rpi.edu/programs/nlpip/ ... Know01.asp
20 watt MR16s are also available with other beam angles.
ccvstmr
Post by ccvstmr »
Greg...many thanx! That explains some of the mysteries with the bulb identifiers.
So now, looking to get an MR16 2-pin plug in base, 20 watt, 12 volt lamp with a 2" diameter reflector. A warm white LED light would be preferred over the cool white. Hmmm, wonder if the wattage should be increased because of a possible dimmer light output compared to cool white. Need to examine the lamp specs. Great info. Tx Carl B.
Greg_Lewis
I wired a PWM dimmer onto mine so I can run full bright or dim it like the prototype. On some tracks where there is approaching traffic those little lamps can be blinding, so I dim mine just like you would with car headlights. Full bright is wired to bypass the dimmer and dim goes through it. A double-throw switch does it.
