In the middle of the night....
- Greg_Lewis
The subconscious mind is an interesting thing. I'll be trying to solve some sort of shop problem, and I just can't get past a certain point. It might be a fixturing issue, an order-of-operations issue, or perhaps a basic design question. I'll consider plan A, plan B, and even plan C, none of which looks like it is right. I'll give up, head inside for dinner, and then I'll wake up at about 2 a.m. and the answer will pop into my head. This has happened at least three times recently, and when the answer presents itself, it seems so obvious I don't understand why I didn't think of it earlier.
The latest example is the refrigerator doors in my truck camper. If you have an RV or similar, you probably know what happens when you forget to prop the fridge doors open before putting it away. New life forms will develop inside the fridge and your departure will be delayed by the time it takes you to spray it all down with Lysol and clean out the gunk. So I was trying to come up with a way to keep the doors open yet also keep them from swinging farther open and bang against the cabinetry should I need to drive the truck before my next road trip. There are aftermarket thingies to do this, but being stubborn I wanted to come up with my own solution. (Why the manufacturer of the fridge didn't design the latches to do this is beyond me.) Anyhow, I considered several options, none of which were practical. Then last night when I awoke for my 2 a.m. bladder relief, the answer was there waiting for me. Two spring clamps and two short bungees, all of which I already had, and the problem is solved.
And I didn't even have to write it down!
Re: In the middle of the night....
I used to teach my Mechanical Engineering students machining skills. They often have challenges creating process plans: What order to machine surfaces without losing the reference origin of the part.
I suggested that when the are in the shower in the morning, and suddenly get that clear process plan in their brains, then they are starting to think like machinists and Engineers.
And I had many of them excitedly tell me that's exactly what happened!
Brains. Interesting.
Greg_Lewis wrote: ↑Wed Jul 20, 2022 9:38 pm The subconscious mind is an interesting thing...then I'll wake up at about 2 a.m. and the answer will pop into my head. This has happened at least three times recently, and when the answer presents itself, it seems so obvious I don't understand why I didn't think of it earlier.
I’ve solved a lot of “bare metal” computer programming problems while in the shower. I’ve also awakened in the dead of night, not because the bathroom beckoned, but because some stubborn problem on which I’d been working suddenly had a solution. One of those middle-of-the-night inspirations led to one of my U.S. patents.
This phenomenon is not limited to technology, at least not for me. A jazz tune I composed came to me when I had awakened for an unknown reason (I’ve slept erratically ever since my Navy days). Not only did I have a melody in my head, I also had the chord progressions and even the form.
Obviously, the brain doesn’t shut down while you are sleeping. Activity in the cerebrum is ceaseless, and that includes in the areas in which analytical skills exist. This applies to everybody with a functioning brain—which leaves out some politicians. My guess is while you are sleeping, the more primitive areas of the brain are “idling” or “running” at reduced throttle, leaving more energy for the cerebrum to keep working on problems. Disclaimer: I’m not a neuroscientist, so it’s purely speculation.
I'm sure this nighttime epiphany experience happens to many people, so you and I are hardly unique. Sorry!
Happens to me now and then for sure. I've also noticed that I make far fewer dumb mistakes when asleep than awake.BigDumbDinosaur wrote: ↑Wed Jul 20, 2022 11:41 pm I'm sure this nighttime epiphany experience happens to many people.
-- Russell Mac
Interesting. That's usually where I am when I solve such puzzles. I also often solve them while resting, where my head seems to wander a great deal.
It is my belief that one of the things that sorts machinists is their ability to solve setup and machining problems. Those with a good imagination seem to be above others in capability.
Back when I used to be a developer and had a particularly difficult programming problem to solve it would often come to me in my sleep.
Sent from my SM-S908E using Tapatalk
Lizard brain mentality
When we dream we dream "outside the box".
Just yesterday morning I was working on a section of the pasture and contemplating how a person thinks outside the box. Is it a learned behavior or is it innate in some individuals?
While working it occurred to me I have one 20 acre wide open field for hay and beside it another 20 acres with smaller like maybe 3-4 acre sections. When I pull in, I always start in a CW direction... No idea really why other than that is the way I do it.
Gregg
Gregg
Gregg
I’ve tried my best over the years to not go to bed right after monkeying with computer software. I lay there with visions of source code dancing in my brain and by the time I do fall asleep it’s time to get up.
Coriolis effect.....or because you are living in a right handed world (even if you are left handed)curtis cutter wrote: ↑Thu Jul 21, 2022 9:04 am When we dream we dream "outside the box".
Gregg
I always go CROCKwise I guess.Bill Shields wrote: ↑Thu Jul 21, 2022 9:24 amCoriolis effect.....or because you are living in a right handed world (even if you are left handed)curtis cutter wrote: ↑Thu Jul 21, 2022 9:04 am When we dream we dream "outside the box".
Gregg
Gregg
Don't want to climb cut that hay.
