Anyone know what this is?
It’s all cast. The ring is about 18” in diameter (I don’t have it in front of me to actually measure) and it’s separate from the base. It rolls on two pairs of bearings. There is a clamping bolt in the center of the base that locks it from spinning.
Guy picked this up from a flea market. The person he bought it from found it at some relatives house but didn’t know anything else about it. He asked me to sandblast it and turn it into a motorized display that holds whatever it was originally designed for. I just have no clue what that may have been.
Anyone know what this was
Re: Anyone know what this is?
Mr thinks it is a frame for a circular glass clock
As the glass rotates, it keeps time by way of a weighted hand.
Had a small one at home when I was a kid.
Possible, but I don’t think that’s it. It’s not motorized. There doesn’t appear to be anything missing so it must have been manually positioned. Seems like some sort of rebuilding stand to me.
Ah..ok...seems quite plausible
The clock we had used a synchronous motor driving a rubber wheel that caused the disc to rotate and was totally hidden in the base.
Could it have held a globe of Earth?
- liveaboard
The company still exists (they have a facebook page).
You could ask them I suppose.
It's a real head scratcher…. Must be Ford related, I don't think Motorcraft ever made anything not tied into Ford products.
Can't picture it as a tool. Maybe part of a dealership/parts dept. display. Probably not a counter item as it's intended to be screwed down.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
When I first saw it the thing that popped up into my head was a jig/positioner for rebuilding brake drums. I have no idea why I thought that since I’ve never rebuilt a drum, but that’s what stuck hahaha.
Along the ring there are three spots that seem like it would be to hold something. Two of the places protrude out from the ring and have grooves cut into them like something should slide into the grooves. The last point is a big Allen head set screw that seems like it would lock whatever went into it in place inside the ring. The guy who bought it has been asking around too and someone said they thought it was for rewinding stators. Seems really large for something like that, but I guess it’s possible?
IF REWINDING STATORS of that diameter..I would think that it is a bit lightweight....
Agreed.Bill Shields wrote: ↑Fri May 20, 2022 10:41 am IF REWINDING STATORS of that diameter..I would think that it is a bit lightweight....
Motorcraft started in the 50's and ended in 1961 when Autolite was bought by Ford. The brand returned in 1972. I figure your item is from that 50's era.
Can it actually rotate 360? Looks like that nub on the rim would interfere.
I still think it is part of a display….. but what would be the point of it being able to be repositioned?
3/4" Hunslet 4-6-0
3/4" Hunslet 4-6-0
