Aluminum garage door panels
Hi All, garage door went up while latch was in place ,OUCH!, anyway there are some buckles that I would like to straighten out, looking for suggestions, one I have was to cover the area with aluminum foil , warm the area with a heat gun, then hit the area with an inverted can of compressed air to cool it.
Geo
Geo
Re: Aluminum garage door panels
I would believe in this case a picture would be worth a thousand words.
Gregg
This is the best I have, I have straightened some out.
Geo
Geo
Try backing up with a heavy piece of wood, and tapping gently with a rubber hammer.
Insulated door?
Yes, insulated.
Geo
Geo
Most likely won't be able to do much with the wrinkles. I see new panels in your future.
Oh, by the way, the panels are steel, magnets don’t stick to Al.
Geo
Geo
On some doors, the insulation is in panels, which can be removed, and on others, it is between two metal panels like a sandwich. Your choices probably are to replace a few panels, or if the door still works ok, live with the wrinkles until there is another reason to replace the door.
There is a good reason the door locks are generally disabled when a door opener is installed….. The opener keeps it locked. It'll be more spectacular next time you do it as the panels are already compromised.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
The latch has been removed and I think I will just be replacing the top panel, I managed to straighten out the other dents fairly well, once the top panel is replaced it will be good enough.
Reason: Photo Orientation
Geo
Geo
Does your garage opener have a clutch in it? I would think it should take very little force to lift a properly adjusted door.
Gregg
