Arizona Gandy Dancers
Forum rules
Re: Arizona Gandy Dancers
Post by NP317 »
'Going to Hurl Bert back to steam operation?
ChipsAhoy
Post by ChipsAhoy »
No, fraid not. Would be nice tho.
ChipsAhoy
Post by ChipsAhoy »
Got it off display and into the CarBarn. Next step was to remove the trucks and driver and begin reguaging from 14" to 15".
Maybe move each driver outward by 1/2". Drivers have been welded to ths axles. Making it difficult to determine original axle diameter. So as determine what to cut without removing material from the axle.
That won't work.
So maybe replace the axle. This requires boring the axle out of the center of the wheel.
That won't work either! (Sorry, somehow the pic rotated 90' clockwise and I can't figure how to get it back!!)
Maybe... split the axle and install a slug and sleeve in the middle to widen the whole mess.
Erskine Tramway
Post by Erskine Tramway »
ChipsAhoy wrote: Thu Sep 22, 2022 7:08 am
That would work, assuming there isn't a gear or something in the middle of the axle that would interfere. I'd mill a groove in the axle to fit a key to keep the quartering correct before I cut it.
Mike
ChipsAhoy
Post by ChipsAhoy »
Mike:
We did exactly that! Actually, while I had it in the mill, I chalked up a piece of tool steel and ran the table back and forth to scribe a line for the shop to index it all with.
We ended up taking the axles to a larger professional shop whose specialty is rebuilding heavy equipment rams. They have a method of splicing rams used on Dozers and Excavators. We put the two axles back on the Hurlburt, ran it first on just the rear axle... went fine. Then we reinstalled the drive rods and held our collective breath.... drives perfect, really smooth....lucky us!
Yesterday we finally got our Governmental permits.... Thanks to Glenn Brooks who put the whole permit package together for us. And we began laying track...first permenant panel goes out the car barn.
Mike is running the Hurlburt in and out, then in and out, and again in and out of the car barn.... we had to shut him down to get back to work!!!
After we hid the keys to the Hurlburt.....
Three permenant panels are placed in prep for building the crossing!!
One of the Gandy Dancers, Raquel pulling nails from one the hundreds of 4 x 4s donated to ...
Sahuaro Central Shortline Railroad.
Scotty
ChipsAhoy
Post by ChipsAhoy »
Now, the next challange... pouring concrete for the first road crossing.
Gonna be a long day tomorrow
Scotty
Matt.Starman
Post by Matt.Starman »
Just curious...what on center tie spacing are you guys using?
Matt Starman
Greenleaf Locomotive Works
Greenleaf, Idaho
STRR
Post by STRR »
f you need information on Tie Spacing, I have posted a Tie Spacing Chart in the General Discussion - Resource Section / page 2 (at the bottom)
A lot of good information there.
Good Luck,
Terry
Reason: Added link to referenced post
ChipsAhoy
Post by ChipsAhoy »
Finally got our first crossing poured.
So now we are up to 1st of three road crossings complete, 260 feet of track placed of which 200 feet is mainline (not aligned, leveled or ballasted yet). First switch actuall tied in.
Off and Running!!! again
Glenn Brooks
Post by Glenn Brooks »
Nice progress. Good to see.
Glenn Brooks
Matt.Starman wrote: Sun Nov 06, 2022 10:10 am Just curious...what on center tie spacing are you guys using?
Matt, I think they are using 20” centers, with 4”x4” ties. I just use the length of my framing hammer + a bit, if Iam driving spikes…
Erskine Tramway
When I was asked to specify new ties for the track that washed out at the R&GN several years ago, I specified 4x6x36 ties on 20" centers. That's pretty much what Sir Arthur Heywood used, except his ties were cast Iron.
Mike
