2 1/2" scale 4-6-0 build
Re: 2 1/2" scale 4-6-0 build
Bozo makes a visit every so often in my shop I have known him for a while. Jim
No problems just solutions.
Nice, keep it up and before long they will be done!
Thanks Odyknuck for the encouragement those that have never traveled down the path don't realize the commitment we take on. Jim
Yep, without perseverance not much gets done. I work on mine just about every day along with remodeling a bathroom at the same time.
Setting up for boring the rods took a little thinking. Drilled and reamed the pivot point on the rod more to come on that later.. Stepped off the drive journal drilled and bored. Turned a slip fit stub to the bore and a taper at the last to capture the dummy rod which has a slightly larger bore. Used a coaxial indicator to locate the second bore. The drill press vise is used only to hold the rod in place when the tie downs need to be moved. Jim
Rods for 2 1/2" scale 4-6-0
There is a lot of satisfaction in figuring out the setups and finally having made a nice set of rods.
Keep up the good work.
Hi Andy, agreed on the satisfaction and the challenges. I look forward to them every time I get back to working on the locomotive. Jim
Drilled and tapped for zerk
Drilled root of fork and sawed. My cutter did not quite reach the bottom of the hole. Will file later
Cleaned up slot with a cutter
Located reamed hole with a coaxial indicator
The pivot pin was made out of a shoulder bolt with the head cut off.
Jim
Jim
Looking good Jim. Keep at it, you're making lots of progress.
Thanks Steve for the support.
Pivot point on the rear rod drilled, bored, and the brass pressed in.
The flange on the bearings were thinned and pressed home.
Jim
Jim
Jim, your almost there on the rods, looking good.
