2 1/2" scale 4-6-0 build
Re: 2 1/2" scale 4-6-0 build
Started on the tender bolsters and pins.
Bolster plate is 3/8×3 20 inches long. Found center drilled 1/4" then dropped the chuck and inserted a MT3 1"drill . The size was chosen because of the center hole in the table.
- Attachments
- 20230222_121613.jpg (636.72 KiB) Viewed 21213 times
- 20230222_135015.jpg (713.85 KiB) Viewed 21213 times
- 20230222_135211.jpg (842.54 KiB) Viewed 21213 times
No problems just solutions.
The pins were turned out of 2" hot rolled.
- Attachments
- 20230220_144500.jpg (724.21 KiB) Viewed 21212 times
- 20230222_120251.jpg (888.32 KiB) Viewed 21212 times
- 20230222_120308.jpg (907.12 KiB) Viewed 21212 times
- 20230222_144557.jpg (572.96 KiB) Viewed 21212 times
Glad to see the use of hot rolled steel. I’ve been having good luck with the hot rolled variety. With cold rolled flat stock I was getting distortion. My plans have “C.R.” in the parts tables so using hot rolled makes me feel like I’m a penny pincher.
New to live steam
Building 3/4” 4-8-4 Northern &
1” 4-6-2 Pacific
1” 4-6-2 Pacific
Hi Bushav
Hot rolled is fine for general work in my opinion. Jim
The front end got some high temp paint. Jim
- Attachments
- 20230223_133126.jpg (1016.44 KiB) Viewed 21113 times
Always nice to see some paint on our projects. Gives ya the sense of accomplishment.
Back at it.
- Attachments
- 20230227_162920.jpg (656.11 KiB) Viewed 21010 times
- 20230227_162928.jpg (680.12 KiB) Viewed 21010 times
- 20230228_155134.jpg (444.45 KiB) Viewed 21010 times
- 20230228_155150.jpg (517.22 KiB) Viewed 21010 times
- 20230302_144327.jpg (679.33 KiB) Viewed 21010 times
- 20230302_152637.jpg (554.81 KiB) Viewed 21010 times
More of the tender beginnings. Jim
- Attachments
- 20230302_153511.jpg (647.52 KiB) Viewed 21009 times
- 20230302_153610.jpg (767.46 KiB) Viewed 21009 times
- 20230302_161328.jpg (570.21 KiB) Viewed 21009 times
- 20230302_163036.jpg (465.55 KiB) Viewed 21009 times
- 20230302_163117.jpg (692.09 KiB) Viewed 21009 times
Curious if the steel plate and or tubing pulled on you after welding?
I'm not a welder nor a machinist but I play them on chaski.
Ody i find if you keep it clamped till it cools works on keeping the warping to a minimum. Jim
Would doing it TIG vs MIG have any effect on warping? I'd think MIG would be the go to for this sort of thing and would be choice for a car frame etc.
I don't have a tig but maybe in the future. I welded it with my mig. It is a 250 amp hobart. This thing will get hot . Jim
