Power feed for mill table
Re: Power feed for mill table
You can get where you want to go but seriously doubt it will be bolt-on
These are pictures of Rockwell mills with power feeds attached.
http://www.chaski-test.com/pictures/362 ... ined01.JPG
https://format-com-cld-res.cloudinary.c ... 13_JPG.jpg
https://i.ytimg.com/vi/Bl362Z9QO-k/hq2.jpg
https://storage.bhs.cloud.ovh.net/v1/AU ... 3bc091.jpg
Have a nice day,
Mike
Mike
- Gary Armitstead
Emfinger,
This power feed will work on your Rockwell! Think "outside the box". Put this unit on the LEFT hand side of your mill table. Just remove the handle from the lead screw and attach the drive gear that comes with this unit. follow the instructions and install on the end of your table. I've had this unit since last December and use it every day cutting aluminum AND steel. It has rapid traverse for fast movement of the table and a full feed adjustment for cutting anything. Available from Amazon for $385. It was only $275 last year. Made by Shars (China) and distributed from Chicago. You might have to make a bushing for the leadscrew (depending on the diameter). The drive gear is 17mm ID on the gear. And you might have to make an adapter for the gear to the drive collar on the lead screw. But this was easily done with my lathe and the mill combined.
If you need more pictures of my install and some installation tips, just ask and I can post them. BTW, this unit is on my 41 year old ENCO Mill/Drill. I was really sorry it took me forty years to finally put a power feed unit on this machine. Once you have it installed, you WILL use it everyday!!
img]https://www.largescalecentral.com/files ... ze-jpg/img]
Gary Armitstead
Burbank, CA
Member LALS since 1980
Member Goleta Valley Railroad Club 1980-1993
Burbank, CA
No picture, just a site that wants me to sign up for. Is that what you want me to do?
Tom Emfinger
Tom Emfinger
- Gary Armitstead
I have never liked posting photos on this website! It NEVER works the same way twice.
Send me your email address and I will send you ALL of the photos I have of the Shars unit I installed on my Enco mill/drill. These units are great for all small mills OTHER than Bridgeport or Bridgeport clones.
My email address is: grmstd@gmail.com
Gary Armitstead
Burbank, CA
Burbank, CA
YouTube has a video showing a x axis power feed on the 21-100.
It sure looks to me to be an aftermarket power feed similar to the "wen" type power feed.
Do a search for "Rockwell 21-100" and it pops right up
Have a nice day,
Mike
Mike
Yes Mike it pops right up.
However none of the flicks show putting a power drive on a 21-100 or did I miss it?
Yes, one of the videos has it installed already.
Search for "Rockwell Vertical Mill".
Have a nice day,
Mike
Mike
Looking at one of the video's it appears to be made by "Central Machinery"
What is the diameter of the x axis screw at the point where the keyway is cut?
Have a nice day,
Mike
Mike
If the kit has this mounting it is for a Bridgeport.
- Attachments
- mounting.jpg (24.28 KiB) Viewed 8042 times
