Castor wheels for the mill
- liveaboard
Re: Castor wheels for the mill
My idea is to build the pump from scratch.
Bottle jacks run at around 600 bar (8500 psi), so their pumps have tiny volume.
Since my design pressure is just 5% of that, a bigger volume pump will work better, and all it needs is a hole with an Oring groove, a rod on a pivoting stick, and a couple of check valves that are easily made with a steel ball in a hole.
I might need a bit of brass in the bottom to get a seal (drill a small hole then tap a larger hard steel ball against it to create a seat).
Pressure relief valve is an interesting problem; it could be built from scratch in a similar way, or maybe I'll find one from a car engine.
Anyway, other problems have raised their heads here so I'm afraid this fine idea will have to be placed on the back burner for a while.
Why not a grease gun?
Who says it has to be oil?
- liveaboard
Yeah, I thought of that.
They're CHEAP!
But think about the tiny piston, it would take an hour to pump it up.
And release would be difficult if it was grease.
You can put oil in a grease gun, I have one with way oil in it for pushing into the fittings on my mill.
But volume problem remains; and no PRV, no release to let the oil out of the pistons either.
So, thanks for the thought,
They're CHEAP!
Air cylinders with the shop air compressor? Leaks are easier to clean up.
Pete
Pete
i saw a $70 hydrotest pump on amazon the other day....
The air cylinders only seem like a good idea Pete until you run the real world numbers and figure out how large the cylinders and pistons have to be with 120-150 psi of shop air to lift I'm estimating about 3,000 lbs for Mark's new mill. Call it 3 air cylinders as the minimum stable number, so 1,000 lbs on each roughly, 150 psi of shop air needs at least 6.6 square inches of piston surface area to lift that 1,000 lbs of weight plus add whatever frictional losses there might be. At least 7-8 square inches of piston surface area. So to be safe and it would work for sure, about 2.5"-3" diameter on the pistons. Not impossible, but hydraulic can be much more compact and efficient because of the higher pressures. Now if Mark just happened to have a 3k psi dive tank compressor handy, then yeah it would be the best and easiest.
- liveaboard
My compressor is 10 bar (150lbs) and as the pistons will be made from the castor hubs, they already exist.
The pressure required to lift the mill (1.3 tons) is already calculated at around 30 bar (450 lbs).
That already figures in that the front wheels will be considerably higher loaded than the rear.
A leak would indeed be a mess. That's the risk with low budget Orings instead of using hydraulic seals.
I can make it so that I can recut the grooves and fit the expensive seals if necessary.
That would only happen after my floor gets soaked with oil.
I found an old jack bottom (I used the jack cylinder for my press). It has a needle release valve, a check valve, and a pressure release valve.
600 bar one, but I should be able to change that.
Anyway, I can't work on this at the moment.
- liveaboard
I had to move my whole workshop, which took time as I need to run power, water, and data lines 250 yards.
I've now managed to get some work done;
I cut the castor pivot rods down to 46mm with a 50mm lip.
Made cylinders with Oring grooves and threaded caps. I lifted the mill onto my small workbench, drilled and tapped 15 10mm bolt holes. The lower bolt holes are blind into the cast iron base plate. Upper ones penetrate the top of the cutting oil reservoir.
Made the mountings and welded them onto the cylinders.
Pressure tested at 40 bar, 600 psi. To my pleasant surprise, none of my home made little puck cylinders leaked at all. Now waiting for the paint to get hard before assembly.
I still have to make the pump; I need the mill for that so I'll put it into the workshop first.
I am new to machining. The last time with a machine shop was Hughes Aircraft Company in Torrance, California. Before that Research Tool and Die, and before that high school. I just bought a Precision Matthews PM-728V-T. I installed castors/levelers on its stand and it seems to work well. It is easy to spin and move if you go slow.
- liveaboard
It looks like you'd need to wind down each wheel by hand?
I mounted my homemade ones on the machine but I'm having trouble bleeding the air out.
I think it sucks in air around the Orings when I pull the pistons down. I'll try another method.
- liveaboard
I bolted the wheels to the machine.
I thought I could bleed the hydraulics by pumping the cylinders by hand with a tube in a can of oil; but air pulls in around the orings on vacuum.
So I made a pressurized reservoir to solve the problem and get everything filled so I can move the mill before I make the pump.
Just a fizz water bottle with 6 psi of air to push the oil down the tubes.
Filled with oil and closed with a valve, the wheels support the mill at the predicted oil pressure of 30 bar, around 450 psi.
Then I hoisted it up on the tractor to take it out to the workshop;
Rolling it to the back of the shop container; I had to remove my saw, drill press, and bench vise.
After opening the valve to let the oil out, the old girl settles into position.
I started working on the pump unit; it's going well but I had to stop until I get the orings for it.
Nice! Well done.
