John's Clishay build log
Berkman
Re: John's Clishay build log
Post by Berkman »
I've never used one but I've heard from several people that the harbor freight titanium ( green) and vulcan ( orange) series welders are pretty nice to use.
dakine
Post by dakine »
Burner Layout
Post by Bill Shields »
Cylinder and piston values are whacko. I would believe 1.250 cylinder and 1.225 for the Pistons.
'just pipe' is not necessarily satisfactory for a boiler. You are building a fired pressure vessel with all the intrinsic hazards associated.
Also...if you are going to to a propane fired vertical boiler .. you really should look carefully at the Connor beam engine and the flue layout he used.
Flue area for a vertical boiler can be a different critter than for a horizontal coal boiler.
dakine
Post by dakine »
Boiler Sheet layout
dakine
Post by dakine »
OK Here it is in B/W
you might want to look here...
http://www.chaski.org/homemachinist/vie ... =8&t=95990
never know what you will find -> esp from tried and true designs.
dakine
Post by dakine »
Thanks Bill, I will spend some time at that series of comments. BTW - what are "Marty Burners"? Haven't found any info on that yet.
Sold by loco parts and others.
Solar burners is another industrial trade name.
If you do a search for Connor in chaski you will find a lot of information.
His boilers with some 300 flues work very well
dakine
Post by dakine »
Thanks I have LOCO parts info
ChipsAhoy
Post by ChipsAhoy »
I would read this prior to spending $.
http://ibls.org/mediawiki/index.php/Marty_Burners
Also look at these.
https://www.bayouclassicdepot.com/produ ... -brass-jet
I am not recommending either of these, I don't have first hand knowledge of either.
But, I have researched and have purchased the material to build a small mountain of the Marty Burners.
I am providing this only as a shortcut for you to help in your research.
Scotty
The bayou burners are a straight jet without a diffuser on the end...and may not be what you want for this type of boiler.
I have a couple and found them to be less than suitable for this situation.
dakine
Post by dakine »
Sheets milled out, received 40" pipe
