Monitor for Acad
Monitor for Acad
Can I connect a 32" TV to a desktop computer to use as a monitor?
Mr.Ron from South Mississippi
Re: Monitor for Acad
If the TV has a VGA or HDMI input you can. If not, an adapter would be required to generate signals that are compatible with the TV's inputs.
Either way, you probably will be underwhelmed with the results. Just as a toilet bowl is a lousy substitute for a drinking fountain, a TV is a poor substitute for a quality computer monitor. The latter is optimized for the high-resolution output of a modern computer's video circuits, which is not usually the case with a TV.
I have 4 of them connected to my desktop using hdmi, display ports and dvi cables and converters.
The tvs do 1900 x 1400 resolution
In reality -> today's tvs are just a computer monitor without all the connections on the back.
Yes ACAD will run them as long as your computer will talk to them.
Thanks for your information. I've been looking for a monitor larger than my 21" monitor, buy can't seem to find one.
Are you talking about a flat screen Monitor?
Last time I checked Viewsonic makes them up to 34 inches diagonal.
Any computer or TV screen can be used. 34" to 80" autocad does not care
People still use AutoCad???Bill Shields wrote: ↑Sun Jun 20, 2021 3:00 pm Any computer or TV screen can be used. 34" to 80" autocad does not care
I sure hope so! I was gifted ACAD 14, along with the manuals and code. I have yet to install it, but I'm hoping it functions. I have a little experience with ACAD 10, so I'm slightly familiar with the functions. None of it is very intuitive for me, so I'd like to avoid a huge learning curve by trying anything else. I welcome your comments in that regard.BigDumbDinosaur wrote: ↑Mon Jun 21, 2021 1:08 amPeople still use AutoCad???Bill Shields wrote: ↑Sun Jun 20, 2021 3:00 pm Any computer or TV screen can be used. 34" to 80" autocad does not care
I should note that I am not all that interested in three axis modeling. My primary interest is in generating prints for machining. That's how my head works (such as it is, anyway).
I have acad 14 and fusion all running on the same computer.
I’ve worked daily with the progression of Autocad versions since the ‘90s. If you have some familiarity with Autocad 10, you’ll get comfortable with 14 in short order. Don’t get discouraged if everything looks different on the screen when you first open it up - Autodesk has a nasty habit of “improving” the graphical interface every few years. Stick with it, the underlying framework and commands tend to remain fairly consistent. Also - get yourself a mouse with a wheel center button and configure it to pan/scroll/zoom.
Jon W
Somewhere North of Boston
I too have no interest in three-axis drafting, and use an inexpensive 2-D CAD package called DeltaCad—my entire F7 was designed in DeltaCad.Harold_V wrote: ↑Mon Jun 21, 2021 1:39 amI sure hope so! I was gifted ACAD 14, along with the manuals and code. I have yet to install it, but I'm hoping it functions. I have a little experience with ACAD 10, so I'm slightly familiar with the functions. None of it is very intuitive for me, so I'd like to avoid a huge learning curve by trying anything else. I welcome your comments in that regard.BigDumbDinosaur wrote: ↑Mon Jun 21, 2021 1:08 amPeople still use AutoCad???Bill Shields wrote: ↑Sun Jun 20, 2021 3:00 pm Any computer or TV screen can be used. 34" to 80" autocad does not care
I have never liked Autocad and as it progressed from MS-DOS to Windows 3, 95, 98, etc., it became infested with creeping featurism, making it cumbersome and less intuitive, to me at least. I have several clients who do a lot of mechanical drafting in their business (one such client designs and builds tooling for the canning industry—their progressive dies are works of art), and none uses Autocad.
