Fitchburg Chloe: The Best of Both Worlds
ccvstmr
Re: Fitchburg Chloe: The Best of Both Worlds
Post by ccvstmr »
Mike Walsh wrote: Mon Jan 09, 2023 10:35 pm [This nozzle was used to lift a scale model of Marvin the Martian's rocket weighing 500 lbs to 500 feet. Good stuff!
So, whatever happened to the Earth shattering KaBoom? After all, the Earth was blocking Marvin's view of the moon! :lol: Good stuff. Carl B.
Andypullen
Post by Andypullen »
Benjamin Maggi wrote: Mon Jan 09, 2023 2:34 pm But building engines isn't rocket science...
Being in Utah, I assume he's working for Thiokol... Which would be Solid Rocket Boosters... And those are rocket motors, not rocket engines ;)
Meanwhile here's a little rocket motor eye candy... A nozzle for a 6" diameter rocket motor machined by yours truly. Phenolic carrier with a graphite insert. Throat is 2" diameter. This nozzle was used to lift a scale model of Marvin the Martian's rocket weighing 500 lbs to 500 feet. Good stuff!
He’s in California.
I built a liquid fueled engine for some Midshipmen a number of years ago. The injector wasn’t right as I recall. The oxygen and fuel mix wasn’t right. Didn’t generate enough thrust. Very cool project though. I’ll find a photo.
Andypullen
Here it is.
