Amazing machine work
Re: Amazing machine work
from what i hear - crankshafts are worth their weight in gold....
Crankshafts and propeller shafts are still out there, but getting harder to obtain, as they are basically being hoarded.
If you were a boat racer, the first thing you did was remove the propeller shaft/reduction case and toss it in the dumpster, as it wasn't needed...
Going together, but too may fiddly little parts when you get down to the end...
Oh, you mean like this arrangement to secure a threaded plug?BigDumbDinosaur wrote: ↑Wed Nov 09, 2022 2:54 pmThe British were notorious for using 10 parts to do the work of five,
A simple piece of safety wire to secure the plug would have worked just fine.
GlennW wrote: ↑Wed Nov 16, 2022 1:29 pmOh, you mean like this arrangement to secure a threaded plug?BigDumbDinosaur wrote: ↑Wed Nov 09, 2022 2:54 pmThe British were notorious for using 10 parts to do the work of five,
Yep! That's exactly what I mean.
Also, a long-standing joke back in the day about British automobile engine manufacturers was they didn't understand that oil is a liquid and it’s necessary to seal the engine so it doesn’t leak out.
As a friend once said, "In order to do it's intended job, the lubricant must remain in the crankcase".
One word:
Lucas.
Lucas.
unless it's intended job is to lubricate the outer skin of the aircraft
The only thing they ever built that didn't suck was their vacuum cleaners.
weren't they bought out by Dyson?
Interestingly, the magnetos are Rotax (Lucas) and aren't too bad!
Dyson blows.
